[mapserver-users] Using cluster with spatialite ?
Andrea Peri aperi2007 at gmail.com
Wed Oct 22 11:47:27 PDT 2014
Just to complete information.
At the end the issue was explained to be really not an issue but
instead a break api.
In the mapserver 6.4 is need to use
"Cluster:FeatureCount"
in next coming mapserver 7.x will be use
"Cluster_FeatureCount".
Regards,
Andrea Peri
2014-10-22 16:25 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
> done
> https://github.com/mapserver/mapserver/issues/5021
> Thx,
> A.
> 2014-10-22 15:59 GMT+02:00 Yves Jacolin <yves.jacolin at camptocamp.com>:
>> On Wednesday, October 22, 2014 10:56:41 Jeff McKenna wrote:
>>> On 2014-10-22 10:34 AM, Andrea Peri wrote:
>>> > Hi,
>>> > I found the expalin.
>>> > Seeing the code I see the labelitem is not
>>> > but instead:
>>> > This is different from documentation.
>>> > I guess the issue is in the code.
>>> > If confirmed, I check in last dev in repository and fill an issue if
>>> > necessary.
>>> > Regards,
>>> > Andrea.
>>> Careful, I believe that change was made to the unreleased 6.5-dev
>>> version.  So that is why docs have not been updated for 6.4.1
>>> -jeff
>> I confirm this, I have an old working mapfile with the Cluster:FeatureCount
>> parameter.
>> I will do some testing if I have some time.
>> Y.
>> Responsable Formation et Support
>> Camptocamp France SAS
>> Savoie Technolac, BP 352
>> 73377 Le Bourget du Lac, Cedex
>> Tel (France) : +33 4 79 26 57 98
>> Tel (Suisse) : 021 619 10 43
>> Mob. : +33 6 18 75 42 21
>> Fax : 04 79 70 15 81
>> Mail : yves.jacolin at camptocamp.com
>> http://www.camptocamp.com
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Andrea Peri
> qwerty àèìòù
Andrea Peri
qwerty àèìòù
