[mapserver-users] Square Edges Using labelpoly
Lime, Steve D (MNIT)
Steve.Lime at state.mn.us
Wed Oct 22 14:58:24 PDT 2014
7.0 still suffers from the issue in the second image URL I posted - please file a ticket if you would. On the bright side the label poly now properly includes the lowercase y!
http://maps1.dnr.state.mn.us/cgi-bin/mapserv70?map=/usr/local/mapserver/apps/test/labelpoly/test3.map&mode=map
Steve
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Lime, Steve D (MNIT)
Sent: Wednesday, October 22, 2014 4:49 PM
To: Zach Chehayeb; Håvard Tveite; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Square Edges Using labelpoly
It's an issue with 6.4, I don't have a 7.0 build handy. I'll try it and see. Thomas refactored a bunch of the labeling code in 7.0 so maybe it's not an issue.
From: Zach Chehayeb [mailto:zach.chehayeb at airborne.aero]
Sent: Wednesday, October 22, 2014 4:46 PM
To: Lime, Steve D (MNIT); Håvard Tveite; mapserver-users at lists.osgeo.org
Subject: RE: [mapserver-users] Square Edges Using labelpoly
The two styles suggestion worked. Thank you both for your help!
Steve,
Do you know if this is still an issue with the current release of mapserver? I am running 6.0.3 so I am curious to know if this issue still exists. If so, would you like me to raise a ticket for this?
Regards,
Zach
From: Lime, Steve D (MNIT) [mailto:Steve.Lime at state.mn.us]
Sent: Wednesday, October 22, 2014 2:23 PM
Seems to be the combination of the fill and the outline that forces the rounded outline. Here's a test:
1) Outline, LINEJOIN MITER, LINECAP SQUARE: http://maps1.dnr.state.mn.us/cgi-bin/mapserv64?map=/usr/local/mapserver/apps/test/labelpoly/test1.map&mode=map
2) Fill and outline, LINEJOIN MITER, LINECAP SQUARE: http://maps1.dnr.state.mn.us/cgi-bin/mapserv64?map=/usr/local/mapserver/apps/test/labelpoly/test2.map&mode=map
Besides seemingly not respecting the LINEJOIN/LINECAP values, the label polygon doesn't include the baseline decent of the lower case y. Hmmm...
Sure seems like a bug...
However, you can work around it. Just use two styles. One to draw the outline and one to fill... (see mapfile below)
3) Two styles, outline uses LINEJOIN MITER, LINECAP SQUARE: http://maps1.dnr.state.mn.us/cgi-bin/mapserv64?map=/usr/local/mapserver/apps/test/labelpoly/test3.map&mode=map
Steve
------------ snip ------------
MAP
NAME 'test'
EXTENT 0 0 500 500
SIZE 500 500
FONTSET 'fonts.list'
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
LAYER
NAME 'label'
TYPE POINT
STATUS DEFAULT
FEATURE
POINTS 50 250 END
TEXT 'my label text'
END
LABELITEM 'text'
CLASS
LABEL
POSITION UR
TYPE TRUETYPE
FONT 'arial'
SIZE 40
COLOR 0 0 0
STYLE
GEOMTRANSFORM labelpoly
# COLOR 255 0 0
OUTLINECOLOR 255 0 0
WIDTH 10
LINEJOIN miter
LINECAP square
END # Style
STYLE
COLOR 255 0 0
END # Style
END # Label
END
END
END
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Zach Chehayeb
Sent: Wednesday, October 22, 2014 1:38 PM
To: Håvard Tveite; mapserver-users at lists.osgeo.org
Håvard,
Thanks for your help. Unfortunately, the polygon did not change when specifying "LINEJOIN miter" (see below) and still has curved edges. Any other ideas?
STYLE
ANGLE 0
COLOR 149 149 149
GEOMTRANSFORM "labelpoly"
OFFSET 0 0
OUTLINECOLOR 149 149 149
WIDTH 22
LINEJOIN miter
END # STYLE
Regards,
Zach
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Håvard Tveite
Sent: Wednesday, October 22, 2014 12:17 AM
To: mapserver-users at lists.osgeo.org
LINEJOIN miter
in the STYLE element should work also for labelpoly see http://mapserver.org/mapfile/style.html
LABEL
STYLE
WIDTH 4
LINEJOIN miter
END # Style
END # Label
Håvard
On 2014-10-21 23:37, Zach Chehayeb wrote:
> Hi All,
> Does anyone know if it possible to create a labelpoly (as in GEOTRANSFORM labelpoly) with straight edges instead of curved edges?
> Regards,
> Zach
Håvard Tveite
Department of Mathematical Sciences and Technology, NMBU Drøbakveien 31, POBox 5003, N-1432 Ås, NORWAY
Phone: +47 64965483 Fax: +47 64965401 http://www.nmbu.no/imt/ _______________________________________________
