[mapserver-users] Is kerneldensity_attribute implemented?
Yves Jacolin
yves.jacolin at camptocamp.com
Thu Oct 23 05:04:08 PDT 2014
Hello,
If documentation is not uptodate you can either send a PR or create an issue
with some text and information (where? what?).
More information you give, easier and better it is for us.
Y.
On Thursday, October 23, 2014 8:21:03 Rahkonen Jukka wrote:
> Hi,
> Fine, I could make is work with this knowledge. Is it so that the only
> documentation right now is in the RFC and main documentation page
> http://mapserver.org/documentation.html does not know about dynamic
> heatmaps yet? Might be worth having an own entry in the Output section.
> I was trying to normalize my source data. There seems to be some limited
> possibilities for doing that with source layer and kerneldensity layer: -
> In source LAYER the attribute to be used for weighting can be selected with
> "STYLE SIZE [attribute] END. The [attribute] is selected as it stands and
> no expressions can be used in STYLE - SIZE - In the kerneldensity LAYER "
> processing "KERNELDENSITY_NORMALIZATION" can be used for normalizing data
> by a multiplication factor. - For more advanced normalization it must be
> done in the data because for example expression [POPULATION]/[AREA] can't
> be resolved on-the-fly because expressions are not supported in STYLE -
> SIZE.
> Have I understood right? With some sources of the point layer data there
> could perhaps be a workaround by computing new field on-the-fly inside
> LAYER - DATA: "select geometry, population/area as popar from source" and
> by using then "popar" as size attribute. I made some trials with
> connnectiontype OGR but it was not trivial to make my selection to work
> from a shapefile.
> -Jukka Rahkonen-
> thomas bonfort wrote:
> > Jukka,
> > All the functionality is tested in msautotest, the KERNELDENSITY_ATTRIBUTE
> > is an error is the RFC. To use an attribute use STYLE SIZE [attribute]
> > END in your linked vector layer.
> > thomas
> > On 23 October 2014 06:55, Rahkonen Jukka (Tike)
> > <jukka.rahkonen at mmmtike.fi> wrote:
> > > Hi,
> > > I have tried to use attribute based weights in heatmaps as in RFC 108
> > > example http://mapserver.org/development/rfc/ms-rfc-108.html
> > > processing "KERNELDENSITY_ATTRIBUTE=POP2010"
> > > However, this processing option does not seem to have any affect. It is
> > > not
> > used in the MS autotest mapfile and I wonder if it has been implemented at
> > all yet. Does somebody know?
> > > -Jukka Rahkonen-
> > > _______________________________________________
> > > mapserver-users mailing list
> > > mapserver-users at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/mapserver-users
Responsable Formation et Support
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel (France) : +33 4 79 26 57 98
Tel (Suisse) : 021 619 10 43
Mob. : +33 6 18 75 42 21
Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com
http://www.camptocamp.com
