[mapserver-users] Is kerneldensity_attribute implemented?
Rahkonen Jukka (Tike)
jukka.rahkonen at mmmtike.fi
Thu Oct 23 05:58:04 PDT 2014
I made an issue to Github. By browsing through the list of RFCs there may be also some other features in Mapserver which are best or only documented in corresponding RFCs. That is OK as an initial documentation but if things are a 'changing and usage is perhaps no more exactly as it was written to RFC. It looks like there is usually no considerations in RFCs about how and where to document the fine new features for the users.
-Jukka Rahkonen-
Yves Jacolin wrote:
> Hello,
> If documentation is not uptodate you can either send a PR or create an issue
> with some text and information (where? what?).
> More information you give, easier and better it is for us.
> Y.
> On Thursday, October 23, 2014 8:21:03 Rahkonen Jukka wrote:
> > Hi,
> > Fine, I could make is work with this knowledge. Is it so that the only
> > documentation right now is in the RFC and main documentation page
> > http://mapserver.org/documentation.html does not know about dynamic
> > heatmaps yet? Might be worth having an own entry in the Output section.
> > I was trying to normalize my source data. There seems to be some
> > limited possibilities for doing that with source layer and
> > kerneldensity layer: - In source LAYER the attribute to be used for
> > weighting can be selected with "STYLE SIZE [attribute] END. The
> > [attribute] is selected as it stands and no expressions can be used in STYLE -
> SIZE - In the kerneldensity LAYER "
> > processing "KERNELDENSITY_NORMALIZATION" can be used for normalizing
> > data by a multiplication factor. - For more advanced normalization it
> > must be done in the data because for example expression
> > [POPULATION]/[AREA] can't be resolved on-the-fly because expressions
> > are not supported in STYLE - SIZE.
> > Have I understood right? With some sources of the point layer data
> > there could perhaps be a workaround by computing new field on-the-fly
> > inside LAYER - DATA: "select geometry, population/area as popar from
> > source" and by using then "popar" as size attribute. I made some
> > trials with connnectiontype OGR but it was not trivial to make my
> > selection to work from a shapefile.
> > -Jukka Rahkonen-
> > thomas bonfort wrote:
> > > Jukka,
> > > All the functionality is tested in msautotest, the
> > > KERNELDENSITY_ATTRIBUTE is an error is the RFC. To use an attribute
> > > use STYLE SIZE [attribute] END in your linked vector layer.
> > > thomas
> > > On 23 October 2014 06:55, Rahkonen Jukka (Tike)
> > > <jukka.rahkonen at mmmtike.fi> wrote:
> > > > Hi,
> > > > I have tried to use attribute based weights in heatmaps as in RFC
> > > > 108 example http://mapserver.org/development/rfc/ms-rfc-108.html
> > > > processing "KERNELDENSITY_ATTRIBUTE=POP2010"
> > > > However, this processing option does not seem to have any affect.
> > > > It is not
> > > used in the MS autotest mapfile and I wonder if it has been
> > > implemented at all yet. Does somebody know?
> > > > -Jukka Rahkonen-
> > > > _______________________________________________
> > > > mapserver-users mailing list
> > > > mapserver-users at lists.osgeo.org
> > > > http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Responsable Formation et Support
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel (France) : +33 4 79 26 57 98
> Tel (Suisse) : 021 619 10 43
> Mob. : +33 6 18 75 42 21
> Fax : 04 79 70 15 81
> Mail : yves.jacolin at camptocamp.com
> http://www.camptocamp.com
