[mapserver-users] URL redirection under IIS
Jeff McKenna
jmckenna at gatewaygeomatics.com
Thu May 7 04:42:28 PDT 2015
Hi James,
If you want some Open Source karma you could write all of your IIS notes
as you travel down this path onto the MapServer wiki, for the whole
community: https://github.com/mapserver/mapserver/wiki
-jeff
On 2015-05-07 8:35 AM, James_in_Utah wrote:
> Thanks for the replies. I got it working for the most part by downloading
> and installing the URL Rewrite module for IIS from Microsoft. Using that
> you create a web.config file with rewrite rules in it. The file goes in the
> inetpub\wwwroot directory. Funny thin is, the same rules that worked under
> IIS 7 on Windows 7 don't work under Server 2008. It seems to be much more
> picky. I remember it being much easier under Apache.
> Thanks,
> James
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
