[mapserver-users] Mapserver 7 - CLUSTER layer getfeatureinfo / php mapscript queryByPoint broken?
AndyC79 acowie at gmail.com
Tue Apr 19 03:07:20 PDT 2016
Upgraded to MS 7 from 6.4.1 recently - getfeatinfo requests that used to
work against clustered layers, now return 500s with Apache logs detailing:
End of script output before headers: mapserv
Which as far as I understand means the mapserv process crashed?
request e.g:
http://<server>/cgi-bin/mapserv?map=/path/to/mapfile.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&FORMAT=png8&TRANSPARENT=true&QUERY_LAYERS=TEST&LAYERS=TEST&TILED=true&INFO_FORMAT=application%2Fjson&X=50&Y=50&SRS=EPSG%3A3031&STYLES=&WIDTH=101&HEIGHT=101&BBOX=-925990.5180299012%2C195459.73995354102%2C-432454.67464720976%2C688995.5833362325
I tried also using PHP mapscript to assemble a point query against the
cluster layer, however that also does not seem to work in MS 7. It fails at
the layerObj->queryByPoint method.
Makes me think there's either something fundamentally problematic with
querying CLUSTER layers in MS 7. Or perhaps the way I've had my mapfile
configured is now causing an issue.
** Can anyone confirm that getfeatureinfo / php mapscript queryByPoint is
working against CLUSTER layers in MS 7 ? **
The CLUSTERs draw fine. Just the querying that seems an issue.
Below extract from mapfile. I can provide further details if necessary.
	LAYER
		NAME 'rsr_sites'
		TEMPLATE "../templates/rsr_sites_info_template.js"
		TYPE POINT
		INCLUDE "includes/connection.inc"
		DATA "the_geom FROM (SELECT gid, the_geom, id AS site_id, url, lon, lat
FROM data.rsr_sites) AS query USING UNIQUE gid USING srid=3031"
		INCLUDE 'includes/proj_3031.inc'
		METADATA
			"ows_name" "rsr_sites"
			"ows_title"	"RSR"
			INCLUDE 'includes/default_layer_metadata.inc'
		END
		TOLERANCE 8
		CLUSTER
				MAXDISTANCE 22
				REGION "ellipse"
		END
		PROCESSING 'ITEMS=site_id,url,lon,lat'
		PROCESSING "CLUSTER_GET_ALL_SHAPES=ON"
		LABELITEM "Cluster_FeatureCount"
		CLASSITEM "Cluster_FeatureCount"
		CLASS
			NAME "Multiple Sites - proportional symbol"
			EXPRESSION ("[Cluster_FeatureCount]" != "1")
			STYLE
				MINSIZE 25
				MAXSIZE 50
				SIZE [Cluster_FeatureCount]
				SYMBOL "Circle"
				COLOR '#885e49'
			END
			LABEL
				FONT ATTriumMou-Cond
				TYPE TRUETYPE
				SIZE 7
				MAXSIZE 8
				MINSIZE 7
				COLOR 255 255 255
				ALIGN CENTER
				PRIORITY 10
				PARTIALS TRUE
				FORCE TRUE
				POSITION cc
			 END
		END
		CLASS
			NAME 'Single Site'
			EXPRESSION '1'
			STYLE
				SYMBOL 'Square'
				SIZE 8
				MINSIZE 8
				MAXSIZE 8
				COLOR '#953d38'
			END
		END
	END
Cheers
Andrew
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapserver-7-CLUSTER-layer-getfeatureinfo-php-mapscript-queryByPoint-broken-tp5261838.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
