[mapserver-users] Mapserver 7 - CLUSTER layer getfeatureinfo / php mapscript queryByPoint broken?
thomas bonfort
thomas.bonfort at gmail.com
Tue Apr 19 03:27:36 PDT 2016
Andy: It's a known issue: https://github.com/mapserver/mapserver/issues/5205,
that requires some non trivial amount of work to fix. Funding may help to
get this fixed faster, you could contact Tamas if you wanted to go in that
direction.
Regards,
Thomas
On 19 April 2016 at 12:07, AndyC79 <acowie at gmail.com> wrote:
> Hi,
> Upgraded to MS 7 from 6.4.1 recently - getfeatinfo requests that used to
> work against clustered layers, now return 500s with Apache logs detailing:
> End of script output before headers: mapserv
> Which as far as I understand means the mapserv process crashed?
> request e.g:
> http://
> <server>/cgi-bin/mapserv?map=/path/to/mapfile.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&FORMAT=png8&TRANSPARENT=true&QUERY_LAYERS=TEST&LAYERS=TEST&TILED=true&INFO_FORMAT=application%2Fjson&X=50&Y=50&SRS=EPSG%3A3031&STYLES=&WIDTH=101&HEIGHT=101&BBOX=-925990.5180299012%2C195459.73995354102%2C-432454.67464720976%2C688995.5833362325
> I tried also using PHP mapscript to assemble a point query against the
> cluster layer, however that also does not seem to work in MS 7. It fails at
> the layerObj->queryByPoint method.
> Makes me think there's either something fundamentally problematic with
> querying CLUSTER layers in MS 7. Or perhaps the way I've had my mapfile
> configured is now causing an issue.
> ** Can anyone confirm that getfeatureinfo / php mapscript queryByPoint is
> working against CLUSTER layers in MS 7 ? **
> The CLUSTERs draw fine. Just the querying that seems an issue.
> Below extract from mapfile. I can provide further details if necessary.
> LAYER
> NAME 'rsr_sites'
> TEMPLATE "../templates/rsr_sites_info_template.js"
> TYPE POINT
> INCLUDE "includes/connection.inc"
> DATA "the_geom FROM (SELECT gid, the_geom, id AS site_id,
> url, lon, lat
> FROM data.rsr_sites) AS query USING UNIQUE gid USING srid=3031"
> INCLUDE 'includes/proj_3031.inc'
> METADATA
> "ows_name" "rsr_sites"
> "ows_title" "RSR"
> INCLUDE 'includes/default_layer_metadata.inc'
> END
> TOLERANCE 8
> CLUSTER
> MAXDISTANCE 22
> REGION "ellipse"
> END
> PROCESSING 'ITEMS=site_id,url,lon,lat'
> PROCESSING "CLUSTER_GET_ALL_SHAPES=ON"
> LABELITEM "Cluster_FeatureCount"
> CLASSITEM "Cluster_FeatureCount"
> CLASS
> NAME "Multiple Sites - proportional symbol"
> EXPRESSION ("[Cluster_FeatureCount]" != "1")
> STYLE
> MINSIZE 25
> MAXSIZE 50
> SIZE [Cluster_FeatureCount]
> SYMBOL "Circle"
> COLOR '#885e49'
> END
> LABEL
> FONT ATTriumMou-Cond
> TYPE TRUETYPE
> SIZE 7
> MAXSIZE 8
> MINSIZE 7
> COLOR 255 255 255
> ALIGN CENTER
> PRIORITY 10
> PARTIALS TRUE
> FORCE TRUE
> POSITION cc
> END
> END
> CLASS
> NAME 'Single Site'
> EXPRESSION '1'
> STYLE
> SYMBOL 'Square'
> SIZE 8
> MINSIZE 8
> MAXSIZE 8
> COLOR '#953d38'
> END
> END
> END
> Cheers
> Andrew
> http://osgeo-org.1560.x6.nabble.com/Mapserver-7-CLUSTER-layer-getfeatureinfo-php-mapscript-queryByPoint-broken-tp5261838.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160419/26e8f9c1/attachment.html>
