[mapserver-users] Mapserver 7 - CLUSTER layer getfeatureinfo / php mapscript queryByPoint broken?
AndyC79 acowie at gmail.com
Tue Apr 19 03:56:12 PDT 2016
Hi Thomas,
Thanks for the swift response!
Ok cool, I shall find out if funding may be available for fix, will contact
Tamas if there is.
Cheers
Andrew
On 19 April 2016 at 11:13, tbonfort [via OSGeo.org] <
ml-node+s1560n5261840h24 at n6.nabble.com> wrote:
> Andy: It's a known issue:
> https://github.com/mapserver/mapserver/issues/5205, that requires some
> non trivial amount of work to fix. Funding may help to get this fixed
> faster, you could contact Tamas if you wanted to go in that direction.
> Regards,
> Thomas
> On 19 April 2016 at 12:07, AndyC79 <[hidden email]
> <http:///user/SendEmail.jtp?type=node&node=5261840&i=0>> wrote:
>> Hi,
>> Upgraded to MS 7 from 6.4.1 recently - getfeatinfo requests that used to
>> work against clustered layers, now return 500s with Apache logs detailing:
>> End of script output before headers: mapserv
>> Which as far as I understand means the mapserv process crashed?
>> request e.g:
>> http://
>> <server>/cgi-bin/mapserv?map=/path/to/mapfile.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetFeatureInfo&FORMAT=png8&TRANSPARENT=true&QUERY_LAYERS=TEST&LAYERS=TEST&TILED=true&INFO_FORMAT=application%2Fjson&X=50&Y=50&SRS=EPSG%3A3031&STYLES=&WIDTH=101&HEIGHT=101&BBOX=-925990.5180299012%2C195459.73995354102%2C-432454.67464720976%2C688995.5833362325
>> I tried also using PHP mapscript to assemble a point query against the
>> cluster layer, however that also does not seem to work in MS 7. It fails
>> at
>> the layerObj->queryByPoint method.
>> Makes me think there's either something fundamentally problematic with
>> querying CLUSTER layers in MS 7. Or perhaps the way I've had my mapfile
>> configured is now causing an issue.
>> ** Can anyone confirm that getfeatureinfo / php mapscript queryByPoint is
>> working against CLUSTER layers in MS 7 ? **
>> The CLUSTERs draw fine. Just the querying that seems an issue.
>> Below extract from mapfile. I can provide further details if necessary.
>>         LAYER
>>                 NAME 'rsr_sites'
>>                 TEMPLATE "../templates/rsr_sites_info_template.js"
>>                 TYPE POINT
>>                 INCLUDE "includes/connection.inc"
>>                 DATA "the_geom FROM (SELECT gid, the_geom, id AS site_id,
>> url, lon, lat
>> FROM data.rsr_sites) AS query USING UNIQUE gid USING srid=3031"
>>                 INCLUDE 'includes/proj_3031.inc'
>>                 METADATA
>>                         "ows_name" "rsr_sites"
>>                         "ows_title"     "RSR"
>>                         INCLUDE 'includes/default_layer_metadata.inc'
>>                 END
>>                 TOLERANCE 8
>>                 CLUSTER
>>                                 MAXDISTANCE 22
>>                                 REGION "ellipse"
>>                 END
>>                 PROCESSING 'ITEMS=site_id,url,lon,lat'
>>                 PROCESSING "CLUSTER_GET_ALL_SHAPES=ON"
>>                 LABELITEM "Cluster_FeatureCount"
>>                 CLASSITEM "Cluster_FeatureCount"
>>                 CLASS
>>                         NAME "Multiple Sites - proportional symbol"
>>                         EXPRESSION ("[Cluster_FeatureCount]" != "1")
>>                         STYLE
>>                                 MINSIZE 25
>>                                 MAXSIZE 50
>>                                 SIZE [Cluster_FeatureCount]
>>                                 SYMBOL "Circle"
>>                                 COLOR '#885e49'
>>                         END
>>                         LABEL
>>                                 FONT ATTriumMou-Cond
>>                                 TYPE TRUETYPE
>>                                 SIZE 7
>>                                 MAXSIZE 8
>>                                 MINSIZE 7
>>                                 COLOR 255 255 255
>>                                 ALIGN CENTER
>>                                 PRIORITY 10
>>                                 PARTIALS TRUE
>>                                 FORCE TRUE
>>                                 POSITION cc
>>                          END
>>                 END
>>                 CLASS
>>                         NAME 'Single Site'
>>                         EXPRESSION '1'
>>                         STYLE
>>                                 SYMBOL 'Square'
>>                                 SIZE 8
>>                                 MINSIZE 8
>>                                 MAXSIZE 8
>>                                 COLOR '#953d38'
>>                         END
>>                 END
>>         END
>> Cheers
>> Andrew
>> View this message in context:
>> http://osgeo-org.1560.x6.nabble.com/Mapserver-7-CLUSTER-layer-getfeatureinfo-php-mapscript-queryByPoint-broken-tp5261838.html
>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> mapserver-users mailing list
>> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5261840&i=1>
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> [hidden email] <http:///user/SendEmail.jtp?type=node&node=5261840&i=2>
> If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.x6.nabble.com/Mapserver-7-CLUSTER-layer-getfeatureinfo-php-mapscript-queryByPoint-broken-tp5261838p5261840.html
> To unsubscribe from Mapserver 7 - CLUSTER layer getfeatureinfo / php
> mapscript queryByPoint broken?, click here
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=5261838&code=YWNvd2llQGdtYWlsLmNvbXw1MjYxODM4fDE4MDMwOTM1MDk=>
> NAML
> <http://osgeo-org.1560.x6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapserver-7-CLUSTER-layer-getfeatureinfo-php-mapscript-queryByPoint-broken-tp5261838p5261850.html
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160419/fd7dbc4a/attachment-0001.html>
