[mapserver-users] Test : wfs:wfs-1.1.0-Basic-GetFeature-tc5 (WFS does not provide the data)
vineet singh
vini.vineetsingh at gmail.com
Thu Apr 21 01:09:49 PDT 2016
Thanks for quick reply.
Result from DescribeFeatureType :
http://localhost:19090/WFS?Service=WFS&Version=1.1.0&request=DescribeFeatureType
<xs:schema xmlns:tows="http://www.aaaa.com/" xmlns:ogc="
http://www.opengis.net/ogc" xmlns:xs="http://www.w3.org/2001/XMLSchema"
xmlns="http://www.w3.org/2001/XMLSchema" xmlns:gml="
http://www.opengis.net/gml"targetNamespace="http://www.aaaa.com/"
elementFormDefault="qualified" version="1.1">
<xs:import namespace="http://www.opengis.net/gml" schemaLocation="
http://schemas.opengis.net/gml/3.1.1/base/gml.xsd"/>
<xs:element name="worldboundaries" type="tows:worldboundariesType"
substitutionGroup="gml:_Feature"/>
<xs:complexType name="worldboundariesType">
<xs:complexContent>
<xs:extension base="gml:AbstractFeatureType">
<xs:sequence>
<xs:element name="fips" nillable="true" minOccurs="0" maxOccurs="1">
<xs:simpleType>
<xs:restriction base="string">
<xs:maxLength value="2"/>
</xs:restriction>
</xs:simpleType>
</xs:element>
<xs:element name="iso2" nillable="true" minOccurs="0" maxOccurs="1">
<xs:simpleType>
</xs:restriction>
</xs:simpleType>
</xs:element>
<xs:element name="iso3" nillable="true" minOccurs="0" maxOccurs="1">
<xs:simpleType>
<xs:maxLength value="3"/>
</xs:restriction>
</xs:simpleType>
</xs:element>
<xs:element name="un" type="short" nillable="true" minOccurs="0" maxOccurs="
1"/>
<xs:element name="name" nillable="true" minOccurs="0" maxOccurs="1">
<xs:simpleType>
<xs:maxLength value="50"/>
</xs:restriction>
</xs:simpleType>
</xs:element>
<xs:element name="area" type="int" nillable="true" minOccurs="0" maxOccurs="
1"/>
<xs:element name="pop2005" type="decimal" nillable="true" minOccurs="0"
maxOccurs="1"/>
<xs:element name="region" type="short" nillable="true" minOccurs="0"
maxOccurs="1"/>
<xs:element name="subregion" type="short" nillable="true" minOccurs="0"
maxOccurs="1"/>
<xs:element name="lon" type="double" nillable="true" minOccurs="0" maxOccurs
="1"/>
<xs:element name="lat" type="double" nillable="true" minOccurs="0" maxOccurs
="1"/>
<xs:element name="geom" type="gml:MultiSurfacePropertyType" nillable="true"
minOccurs="0" maxOccurs="1"/>
</xs:sequence>
</xs:extension>
</xs:complexContent>
</xs:complexType>
</xs:schema>
On Thu, Apr 21, 2016 at 11:44 AM, Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> Hi,
> Just by thinking I guess that the test is checking the schema of the
> featuretype first by making a DescribeFeatureType and is not happy with the
> result:
> FAILURE: WFS does not provide data to use in this test
> (a feature type with a simple property (string, integer, double, decimal)
> Please add the result from DescribeFeatureType.
> -Jukka Rahkonen-
> vineet singh wrote:
> Hi,
> I'm test WFS 1.1.0 using ogc compliance tests, all test cases are getting
> passed except one. I'm using tinyows to serve wfs requests.
> I have posted this issue on opengeospatial
> <https://github.com/opengeospatial>/*ets-wfs11
> <https://github.com/opengeospatial/ets-wfs11> ** : *
> *https://github.com/opengeospatial/ets-wfs11/issues/54
> <https://github.com/opengeospatial/ets-wfs11/issues/54>*
> For get feature service, filter is also working fine.
> I'm not able to understand whether this the problem with tinyows or data
> i'm providing or something wrong with test case.
> Any help would be greatly appreciated.
> Thanks,
> Vineet Singh
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160421/a8918018/attachment-0001.html>
