[mapserver-users] Different positions of feature points in MapServer 6.4 and 7.0.1
thomas bonfort
thomas.bonfort at gmail.com
Fri Apr 22 08:56:52 PDT 2016
Thomas,
Unless you provide a zero-effort patch, bribe a maintainer to do it for
you, or persuade a maintainer that the bug is critical, I would say that
there is very little chance the text handling behavior you are seeing with
7.0 will be backported to the 6.4 branch.
Regards,
Thomas
On 22 April 2016 at 17:12, Kloß, Thomas - LISt <
Thomas.Kloss at list.smwa.sachsen.de> wrote:
> Dear MapServer users,
> we are using two different mapserver version in our organization: 6.4 and
> 7.0.1. In each mapfile there is a so called “copyright layer” with some
> origin information:
> LAYER
> NAME Watersign
> GROUP "Orthofotos"
> STATUS ON
> TRANSFORM ll
> TYPE POINT
> MINSCALEDENOM 60
> MAXSCALEDENOM 2000000
> FEATURE
> POINTS 340 -20 END
> TEXT 'Copyright by XYZ'
> END
> CLASS
> LABEL
> TYPE TRUETYPE
> FONT "Sans-Bold"
> SIZE 7
> ANTIALIAS FALSE
> COLOR 200 200 200
> END
> END
> UNITS PIXELS
> METADATA
> WMS_TITLE 'Watersign'
> WMS_SRS 'EPSG:25833'
> wms_enable_request "!GetCapabilities"
> END
> END
> The position of this text layer however differs between the two mapserver
> versions. Although they have the same code in the mapfile, the text layer
> is not shown at the same place but is slightly shifted.
> Do we have to update to 7.0.1 for the text to be at the right place or is
> there an alternative solution?
> Many thanks and kind regards
> Thomas
> mapserver-users at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160422/8ba57277/attachment-0001.html>
