[mapserver-users] RE OGR csv - no field names
Simon Mercier smercier at mapgears.com
Mon Apr 25 10:31:17 PDT 2016
why not use a vrt file instead!  http://www.gdal.org/drv_vrt.html
<OGRVRTDataSource>
     <OGRVRTLayer name="precipitation">
         <SrcDataSource>precipitation.csv</SrcDataSource>
         <GeometryType>wkbPoint</GeometryType>
         <LayerSRS>EPSG:4326</LayerSRS>
         <GeometryField encoding="PointFromColumns" x="lon" y="lat"/>
         <Field name="precipitation_mm" src="prec_mm"/>
     </OGRVRTLayer>
</OGRVRTDataSource>
On 16-04-25 08:01 AM, Steve.Toutant at inspq.qc.ca wrote:
> I don't know why LABELITEM 'filed_3' would not work in your case
> You can try to specify column names by using a  .csvt file
> http://www.gdal.org/drv_csv.html
> Example:
> https://anitagraser.com/2011/03/07/how-to-specify-data-types-of-csv-columns-for-use-in-qgis/
> *Ian Walberg <ian.walberg at airborne.aero>@lists.osgeo.org*
> Envoyé par : "mapserver-users" <mapserver-users-bounces at lists.osgeo.org>
> 2016-04-23 22:50
> A
> 	"mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
> cc
> Objet
> 	[mapserver-users] OGR csv - no field names
> Folks,
> Can a csv file with no field names as the first row be used as an OGR
> source?
> GDAL creates dummy field names, are these passed to mapserver?
> OGRFeature(USA-Hilton):652
>  field_1 (String) = -74.16958
>  field_2 (String) =  40.73526
>  field_3 (String) =  Penn Station
> What do we need in the layer to make this work?
> LABELITEM 'name' - this throws an error, 'field_3' does not seem to
> work either.
> CONNECTIONTYPE OGR
> CONNECTION 'Stations.csv'
> Thanks
> Ian
simon mercier
mapgears
+1.418.476.7139 p101
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160425/e92e7e90/attachment.html>
