[mapserver-users] RE OGR csv - no field names
Ian Walberg ian.walberg at airborne.aero
Mon Apr 25 13:32:59 PDT 2016
Thanks for the ideas.
I think the vrt file needs the csv fields to have names unless I misunderstand.
CSVT file – does this specify the column/field data type? Can the name be specified as well?
Regards
Ian
From: Simon Mercier [mailto:smercier at mapgears.com]
Sent: Monday, April 25, 2016 10:31 AM
To: Steve.Toutant at inspq.qc.ca; Ian Walberg <ian.walberg at airborne.aero>
Cc: mapserver-users at lists.osgeo.org; mapserver-users <mapserver-users-bounces at lists.osgeo.org>
Subject: Re: [mapserver-users] RE OGR csv - no field names
why not use a vrt file instead!  http://www.gdal.org/drv_vrt.html
<OGRVRTDataSource>
    <OGRVRTLayer name="precipitation">
        <SrcDataSource>precipitation.csv</SrcDataSource>
        <GeometryType>wkbPoint</GeometryType>
        <LayerSRS>EPSG:4326</LayerSRS>
        <GeometryField encoding="PointFromColumns" x="lon" y="lat"/>
        <Field name="precipitation_mm" src="prec_mm"/>
    </OGRVRTLayer>
</OGRVRTDataSource>
On 16-04-25 08:01 AM, Steve.Toutant at inspq.qc.ca<mailto:Steve.Toutant at inspq.qc.ca> wrote:
I don't know why LABELITEM 'filed_3' would not work in your case
You can try to specify column names by using a  .csvt file
http://www.gdal.org/drv_csv.html
Example: https://anitagraser.com/2011/03/07/how-to-specify-data-types-of-csv-columns-for-use-in-qgis/
Ian Walberg <ian.walberg at airborne.aero><mailto:ian.walberg at airborne.aero>@lists.osgeo.org
Envoyé par : "mapserver-users" <mapserver-users-bounces at lists.osgeo.org><mailto:mapserver-users-bounces at lists.osgeo.org>
2016-04-23 22:50
A
"mapserver-users at lists.osgeo.org"<mailto:mapserver-users at lists.osgeo.org> <mapserver-users at lists.osgeo.org><mailto:mapserver-users at lists.osgeo.org>
cc
Objet
[mapserver-users] OGR csv - no field names
Folks,
Can a csv file with no field names as the first row be used as an OGR source?
GDAL creates dummy field names, are these passed to mapserver?
OGRFeature(USA-Hilton):652
 field_1 (String) = -74.16958
 field_2 (String) =  40.73526
 field_3 (String) =  Penn Station
What do we need in the layer to make this work?
LABELITEM 'name' - this throws an error, 'field_3' does not seem to work either.
CONNECTIONTYPE OGR
CONNECTION 'Stations.csv'
Thanks
Ian
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
simon mercier
mapgears
+1.418.476.7139 p101
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160425/89feb903/attachment.html>
