[mapserver-users] Mapserver - cascading a remote ESRI REST service
Robert Sanson
Robert.Sanson at asurequality.com
Wed Apr 27 15:12:59 PDT 2016
Thanks for that.
What values should I use for <SizeX> and <SizeY> in the DataWindow section when the service is a tiled cache made up of many different images with differing pixel resolutions?
Thanks,
Robert
-----Original Message-----
From: Even Rouault [mailto:even.rouault at spatialys.com]
Sent: Wednesday, 27 April 2016 8:48 p.m.
To: mapserver-users at lists.osgeo.org
Cc: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>; Robert Sanson <Robert.Sanson at asurequality.com>
Subject: Re: [mapserver-users] Mapserver - cascading a remote ESRI REST service
Le mercredi 27 avril 2016 09:32:36, Rahkonen Jukka (MML) a écrit :
> Hi,
> I copied your XML definition file and made a test with GDAL. My
> command
> was: gdal_translate -outsize 400 400 rest.xml out.tif --debug o
> Result is an error:
> 0ERROR 1: GDALWMS: Unable to download block 0, 0.
> URL:
> http://maps.six.nsw.gov.au/arcgis/rest/services/sixmaps/LPI_Imagery_Be
> st/
> MapServer
> /export?f=image&bbox=15300000.00000000,-5070000.00000000,17810000.0000
> 0000
> 2950000.00000000&size=256,256&dpi=&imageSR=3857&bboxSR=3857&format=ima
> ge/j
> peg&la
> yerdefs=&layers=&transparent=false&time=&layerTimeOptions=&dynamicLaye
> rs=
> HTTP status code: 400, error: (null).
> Add the HTTP status code to <ZeroBlockHttpCodes> to ignore that error
> (see
> http: //www.gdal.org/frmt_wms.html).
> ERROR 1: rest.xml, band 1: IReadBlock failed at X offset 0, Y offset 0
> With another proxy I get similar error but different code HTTP status
> code: 0, error: (null).
> The request is OK and shows a map when sent through a browser.
> Fiddler proxy gives a short explanation about what goes wrong and it
> says that the request headers can’t be parsed. I do not understand
> what it means but it looks obvious that the issue is in GDAL, not in Mapserver.
> Even R. may be reading but you can also send mail to gdal-dev list.
> Include your XML file and ask why gdal_translate -outsize 400 400
> rest.xml out.tif --debug o gives an error.
> -Jukka Rahkonen-
> Robert Sanson wrote:
> Hi
> I am trying to cascade a remote ESRI REST image service via my
> Mapserver mapfile.
> Here is my XML file:
> <GDAL_WMS>
> <Service name="AGS">
> <ServerUrl>
> st/M
> apServer </ServerUrl>
--> white spaces and newline matter inside a XML element (at least for
--> the XML
parser used by GDAL). If you remove them, like the following, it will work
<ServerUrl>http://maps.six.nsw.gov.au/arcgis/rest/services/sixmaps/LPI_Imagery_Best/MapServer</ServerUrl>
> <BBoxOrder>xyXY</BBoxOrder>
> <SRS>3857</SRS>
> <ImageFormat>image/jpeg</ImageFormat>
> </Service>
> <DataWindow>
> <UpperLeftX>1.53E7</UpperLeftX>
> <UpperLeftY>-2950000.0</UpperLeftY>
> <LowerRightX>1.781E7</LowerRightX>
> <LowerRightY>-5070000.0</LowerRightY>
> <SizeX>256</SizeX><SizeY>256</SizeY>
> </DataWindow>
> </GDAL_WMS>
> Here is my mapfile layer:
> LAYER
> NAME sixmaps
> GROUP 'highres'
> TYPE RASTER
> STATUS ON
> DATA "/mnt/gisdata/data/aus/sixmaps.xml"
> PROCESSING "OVERSAMPLE_RATIO=1.0"
> PROJECTION
> "init=epsg:3857"
> END
> METADATA
> "wms_title" "sixmaps"
> "wms_name" "sixmaps"
> "wms_srs" "EPSG:3857"
> END
> END
> When I try and request a map using a WMS GetMap request, this is the
> error message I get:
> <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?> <!DOCTYPE
> ServiceExceptionReport SYSTEM
> "http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
> <ServiceExceptionReport version="1.1.1"> <ServiceException>
> msDrawMap(): Image handling error. Failed to draw layer named
> 'sixmaps'. drawGDAL(): Unable to access file.
> GDALDatasetRasterIO() failed: GetBlockRef failed at X block offset 0,
> Y block offset 0 </ServiceException> </ServiceExceptionReport>
> Can anyone point out where the problem is?
> Many thanks,
> Robert L. Sanson
Spatialys - Geospatial professional services http://www.spatialys.com
