[mapserver-users] Mapserver filter/expression by DATE
drobins d.robins at gisarts.nl
Tue Aug 9 04:56:01 PDT 2016
I have a PostGIS database and I have a column "startdate" and "enddate" in my
database (YYYY-MM-DD format).
What I want to do is make a filter/expression that checks if a certain
selected date falls between those 2 dates.
Example:
I have a checkbox for enable/disable the following layers:
2016
2017
2018
2019
2020
I have an entry in my database with:
startdate: 2016-01-01
enddate: 2019-01-01
If I check the layer 2017, I would like it to check if its between the
start/enddate and if yes, display it.
Is this possible with Mapserver/Openlayers?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Mapserver-filter-expression-by-DATE-tp5280038.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
