[mapserver-users] Mapserver filter/expression by DATE
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Aug 9 05:37:00 PDT 2016
Hello,
You can create your query through the commandline tool 'psql', and once
you have that working you can test through the 'ogrinfo' commandline
tool, using its '-sql' switch.  Then you can test through MapServer with
the 'shp2img' commandline tool, by setting that query within the DATA
statement of your mapfile layer.  See examples at
http://www.mapserver.org/input/vector/postgis.html
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
On 2016-08-09 8:56 AM, drobins wrote:
> I have a PostGIS database and I have a column "startdate" and "enddate" in my
> database (YYYY-MM-DD format).
> What I want to do is make a filter/expression that checks if a certain
> selected date falls between those 2 dates.
> Example:
> I have a checkbox for enable/disable the following layers:
> 2016
> 2017
> 2018
> 2019
> 2020
> I have an entry in my database with:
> startdate: 2016-01-01
> enddate: 2019-01-01
> If I check the layer 2017, I would like it to check if its between the
> start/enddate and if yes, display it.
> Is this possible with Mapserver/Openlayers?
