[mapserver-users] mapcache question
Jukka Sirviö Jukka.Sirvio at mipro.fi
Wed Aug 24 07:09:26 PDT 2016
Hello,
I would like to put a mapcache to be in the middle, in the following chain:
1) original wmts service in local/national crs x   -->  2) mapcache wmts, reprojection to world-wide crs y (3857) -->  3) user interface (OpenLayers v2, Qgis), also in crs y
Mapcache was compiled, and is working a-ok with demo data. But I have trouble to configure mapcache to work as a part in the above chain. As planned, Mapcache should work as a WMTS client down towards target 1 and WMTS server up against target 3, ie. kind of a proxy with crs reprojection and basic auth. Anyway, does this make any sense at all, or is the draft totally irrational?
If the draft is reasonable, could you give some hints on how to proceed related to configuration with mapcache.xml?
-Jukka
Tämä sähköpostiviesti (liitteineen) saattaa sisältää luottamuksellista tietoa, joka on tarkoitettu
vain vastaanottajalleen. Jos et ole oikea vastaanottaja, ilmoita viestin lähettäjälle tapahtuneesta
virheestä ja tuhoa viesti välittömästi. Viestin luvaton julkaiseminen, kopioiminen, jakelu tai muu
käyttö tai toimenpiteisiin ryhtyminen sen perusteella on ehdottomasti kielletty.
This message (including any attachments) may contain confidential information intended for
the person or entity to which it is addressed. If you are not the intended recipient, notify the
sender and delete this message immediately. Notice that disclosing, copying, distributing or any
other use of the message and its information, or taking any action based on it, is strictly prohibited.
