[mapserver-users] mapcache question
Travis Kirstine tkirstine at firstbasesolutions.com
Wed Aug 24 11:13:47 PDT 2016
Jukka,
According to the docs mapcache only support WMS as input.
" A source is a service mod-mapcache can query to obtain image data. This is typically a WMS server accessible by a URL. (There are currently no sources other than WMS implemented, though others may be added later if the need arises)"
If this is still true then your proposed chain will not work.
MapProxy will support a tiled source and I know TMS works  (not sure about WMTS) and handle the reprojection
Regards
-----Original Message-----
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jukka Sirviö
Sent: August-24-16 10:09 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] mapcache question
Hello,
I would like to put a mapcache to be in the middle, in the following chain:
1) original wmts service in local/national crs x   -->  2) mapcache wmts, reprojection to world-wide crs y (3857) -->  3) user interface (OpenLayers v2, Qgis), also in crs y
Mapcache was compiled, and is working a-ok with demo data. But I have trouble to configure mapcache to work as a part in the above chain. As planned, Mapcache should work as a WMTS client down towards target 1 and WMTS server up against target 3, ie. kind of a proxy with crs reprojection and basic auth. Anyway, does this make any sense at all, or is the draft totally irrational?
If the draft is reasonable, could you give some hints on how to proceed related to configuration with mapcache.xml?
-Jukka
Tämä sähköpostiviesti (liitteineen) saattaa sisältää luottamuksellista tietoa, joka on tarkoitettu vain vastaanottajalleen. Jos et ole oikea vastaanottaja, ilmoita viestin lähettäjälle tapahtuneesta virheestä ja tuhoa viesti välittömästi. Viestin luvaton julkaiseminen, kopioiminen, jakelu tai muu käyttö tai toimenpiteisiin ryhtyminen sen perusteella on ehdottomasti kielletty.
This message (including any attachments) may contain confidential information intended for the person or entity to which it is addressed. If you are not the intended recipient, notify the sender and delete this message immediately. Notice that disclosing, copying, distributing or any other use of the message and its information, or taking any action based on it, is strictly prohibited.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
