[mapserver-users] How to point mapserv to my mapfile?
jenia mtl
jenia.ivlev at gmail.com
Sat Jul 23 15:46:15 PDT 2016
Hello.
How can I specify the mapfile path to the mapserv fastcgi process?
My problem is that I get a 502 error when try to access
http://localhost/cgi-bin/mapserv?map=/ms4w/apps/tutorial/htdocs/example1-1.map&layer=states&mode=map
I get:
2016/07/23 17:45:22 [error] 1768#1768: *7 upstream prematurely closed
FastCGI stdout while reading response header from upstream, client:
127.0.0.1, server: localhost, request: "GET
HTTP/1.1", upstream: "fastcgi://127.0.0.1:8001", host: "localhost"
This is how I start mapserver:
`spawn-fcgi -a 127.0.0.1 -p 8001 /usr/bin/mapserv`
I'm thinking it's because I didn't specify a `mapfile`. And in any case,
I'd like to see the error logs from mapserver (error logs configs go to the
mapfile apperently).
So again, where is the `mapfile` or how do I specify the `mapfile` path for
the `mapserv`instance?
Thanks in advance for your kind help.
Jenia
P.S. This is my nginx config:
server {
listen 80;
server_name localhost;
error_log /home/jenia/error.log;
access_log /home/jenia/access.log;
location ~ / {
fastcgi_pass 127.0.0.1:8001;
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160723/265f7d99/attachment.html>
