[mapserver-users] How to point mapserv to my mapfile?
jenia mtl
jenia.ivlev at gmail.com
Sat Jul 23 15:51:30 PDT 2016
I got it.
It's the `map`parameter in the URL.
Thanks in any case everyone.
Writing this email helped me discover the answer ;)
On Sat, Jul 23, 2016 at 6:46 PM, jenia mtl <jenia.ivlev at gmail.com> wrote:
> Hello.
> How can I specify the mapfile path to the mapserv fastcgi process?
> My problem is that I get a 502 error when try to access
> http://localhost/cgi-bin/mapserv?map=/ms4w/apps/tutorial/htdocs/example1-1.map&layer=states&mode=map
> I get:
> 2016/07/23 17:45:22 [error] 1768#1768: *7 upstream prematurely closed
> FastCGI stdout while reading response header from upstream, client:
> 127.0.0.1, server: localhost, request: "GET
> HTTP/1.1", upstream: "fastcgi://127.0.0.1:8001", host: "localhost"
> This is how I start mapserver:
> `spawn-fcgi -a 127.0.0.1 -p 8001 /usr/bin/mapserv`
> I'm thinking it's because I didn't specify a `mapfile`. And in any case,
> I'd like to see the error logs from mapserver (error logs configs go to
> the mapfile apperently).
> So again, where is the `mapfile` or how do I specify the `mapfile` path
> for the `mapserv`instance?
> Thanks in advance for your kind help.
> Jenia
> P.S. This is my nginx config:
> server {
> listen 80;
> server_name localhost;
> error_log /home/jenia/error.log;
> access_log /home/jenia/access.log;
> location ~ / {
> fastcgi_pass 127.0.0.1:8001;
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160723/ced52908/attachment.html>
