[mapserver-users] Where is the error log file?
jenia mtl
jenia.ivlev at gmail.com
Sun Jul 24 12:52:33 PDT 2016
Hello
I want to do the first example in the MS docs but I get:
502 errors: 20 upstream prematurely closed FastCGI stdout while reading
response header from upstream.
So I decided that I definitely need to read the error log from Mapserver
but I can't find it.
So my question is, where is the error log of MapServer?
I launch MS like this:
spawn-fcgi -a 127.0.0.1 -p 8001 /usr/bin/mapserv
I use archlinux. Typically in systemd (which archlinux uses) the error logs
go to a standard place (journalctl). But I can't find them there.
Specifically, I tried do `journalctl --no-pager | grep mapserv`. Didn't
find anything from mapserv. So my question again is where is the error log
of MapServer?
I tried to set a custom error log path, but it didn't work. The error.txt
file is not being written to.
Here is the relevant part of the config:
CONFIG "MS_ERRORFILE" "/home/jenia/mapserver-exercises/error.txt"
DEBUG 5
The rest is just this mapfile (with the paths changed ofcourse):
http://mapserver.org/tutorial/example1-1-map.html#example1-1-map
And I access it using this url:
http://localhost/cgi-bin/mapserv?map=/home/jenia/mapserver-exercises/example1-1.map&layer=states&mode=map
That's the mapfile's ls output:
[jenia at localhost mapserver-exercises]$ ls -l
-rw-r--r-- 1 jenia jenia 2328 Jul 24 14:04
To reiterate, I have two quesiton.
1. Most importantly, where is the default Mapserver error log?
2. What did I do wrong in setting the custom error log?
Thanks in advance for your time and kind help
Jenia
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160724/2b221879/attachment.html>
