[mapserver-users] CONNECTIONTYPE OGR use DIALECT SQLITE
Even Rouault
even.rouault at spatialys.com
Thu Jun 16 04:59:28 PDT 2016
Le jeudi 16 juin 2016 09:04:00, Marco Giana a écrit :
> Hi,
> I have a layer config
> CONNECTION "E:\\All\\Data\\Kingston\\VicMap\\Tab\\KINGSTON_LGA_POLYGON.tab"
> CONNECTIONTYPE OGR
> DATA "SELECT * FROM KINGSTON_LGA_POLYGON"
> wondering, is it possible set DIALECT SQLITE in the MapFile to be able to
> use spatialite SQL rather than OGR_SQL in the DATA tag?
That should work. OGR_DS_ExecuteSQL() is run without any explicit dialect, so
it is the default dialect of each OGR driver that is used, and in the case of
SQLite/Spatialite, it will evaluated by SQLite itself.
> Cheers
> * Marco Giana*
http://www.spatialys.com
