[mapserver-users] CONNECTIONTYPE OGR use DIALECT SQLITE
lars.schylberg at blixtmail.se
Thu Jun 16 04:31:22 PDT 2016
Hi Marco,
We ha a similar discussion last year. I didn't find a direct way to specify sqlite dialect in the data statement. You could however write it in a vrt file where You could set the sql dialect.
An example can be found in this discussion tread:
https://lists.osgeo.org/pipermail/mapserver-users/2015-March/077583.html
Best regards
Lars S.
-----Originalmeddelande-----
Från: "Marco Giana" <marco_giana at technologyonecorp.com>
Till: mapserver-users at lists.osgeo.org
Datum: 2016-06-16 09:04
Ämne: [mapserver-users] CONNECTIONTYPE OGR use DIALECT SQLITE
I have a layer config
CONNECTION "E:\\All\\Data\\Kingston\\VicMap\\Tab\\KINGSTON_LGA_POLYGON.tab"
CONNECTIONTYPE OGR
DATA "SELECT * FROM KINGSTON_LGA_POLYGON"
wondering, is it possible set DIALECT SQLITE in the MapFile to be able to use spatialite SQL rather than OGR_SQL in the DATA tag?
Cheers
Marco Giana
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160616/704fa8e8/attachment.html>
