[mapserver-users] Rendering of adjacent dashed lines
Ziegler Stefan
Stefan.Ziegler at bd.so.ch
Fri Jun 17 13:40:15 PDT 2016
Hi Thomas
Here are the screenshots from QGIS:
https://sogeo.services/tmp/dashed_line_01.png
https://sogeo.services/tmp/dashed_line_02.png
The first result I can get also with MapServer. The second one is the desired result which I'm not able to achieve with MapSever.
Regards
Stefan
> -----Ursprüngliche Nachricht-----
> Von: thomas bonfort [mailto:thomas.bonfort at gmail.com]
> Gesendet: Freitag, 17. Juni 2016 16:41
> An: Ziegler Stefan
> Cc: mapserver-users at lists.osgeo.org
> Betreff: Re: [mapserver-users] Rendering of adjacent dashed lines
> Can you post a screenshot?
> On 17 June 2016 at 16:27, Ziegler Stefan <Stefan.Ziegler at bd.so.ch> wrote:
> > Then I wasn't propably clear about the problem. I can get the desired effect in
> QGIS. The line symbol is a combination of two line symbols. One is dashed, one is solid.
> > Regards
> > Stefan
> > Sent from my iPhone
> >> On 17 Jun 2016, at 16:20, thomas bonfort <thomas.bonfort at gmail.com> wrote:
> >> Hi Stefan,
> >> Unfortunately no. When I said "impossible" I meant it in the general
> >> case, not for MapServer specifically.
> >> Regards,
> >> thomas
> >>> On 17 June 2016 at 16:17, Ziegler Stefan <Stefan.Ziegler at bd.so.ch> wrote:
> >>> Hi Thomas
> >>> Would it be possible to fund such a feature?
> >>> Stefan
> >>> Sent from my iPhone
> >>>> On 17 Jun 2016, at 16:05, thomas bonfort <thomas.bonfort at gmail.com>
> wrote:
> >>>> Stefan,
> >>>> There is no trick/workaround for this aside from preprocessing your
> >>>> data to merge adjacent lines into one. In the general case what you
> >>>> are aiming for is impossible as your adjacent lines will have
> >>>> different lengths but will be using a fixed length dash pattern.
> >>>> thomas
> >>>>> On 17 June 2016 at 12:38, Ziegler Stefan <Stefan.Ziegler at bd.so.ch> wrote:
> >>>>> Hi
> >>>>> I'm trying to render some lines with a pattern. This works and looks great as
> long as the lines are not adjacent. When the lines share a common border the dashed
> lines may look ugly since one dashed line is rendered on top of the other rendered
> dashed line. I tried to add a white solid line under the dashed line:
> >>>>> CLASS
> >>>>> STYLE
> >>>>> COLOR 255 255 255
> >>>>> WIDTH 2
> >>>>> LINECAP BUTT
> >>>>> END
> >>>>> STYLE
> >>>>> COLOR 0 0 0
> >>>>> WIDTH 2
> >>>>> LINECAP BUTT
> >>>>> PATTERN 20 4 2 4 2 4 END
> >>>>> END
> >>>>> END
> >>>>> But the behaviour is still the same. Is there a trick/workaround for this? I'm
> using MapServer 7.0.1.
> >>>>> Best regards
> >>>>> Stefan Ziegler
> >>>>> Freundliche Grüsse
> >>>>> Stefan Ziegler
> >>>>> Kantonsgeometer / Leiter Amt für Geoinformation
> >>>>> Rötistrasse 4
> >>>>> 4500 Solothurn
> >>>>> Telefon +41 32 627 75 96
> >>>>> Telefax +41 32 627 75 98
> >>>>> stefan.ziegler at bd.so.ch
> >>>>> http://www.so.ch
> >>>>> _______________________________________________
> >>>>> mapserver-users mailing list
> >>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
