[mapserver-users] Building Mapserver - missing strlcat... methods
thomas bonfort thomas.bonfort at gmail.com
Fri Jun 24 01:09:40 PDT 2016
Try deleting everything in the build directory and starting again,
might be a cmake cache problem...
On 24 June 2016 at 10:07, Michael Schulz <mandschulz at googlemail.com> wrote:
> Hi,
> I have exactly the same issue here. Trying to build mapserver on SLES 11
> SP4, I have disabled harfbuzz and fribidi:
> cmake .. \
>  -DCMAKE_PREFIX_PATH=/opt/gdal-trunk \
>         -DWITH_CLIENT_WFS=ON \
>         -DWITH_CLIENT_WMS=ON \
>         -DWITH_CURL=ON \
>         -DWITH_SOS=ON \
>         -DWITH_PHP=ON \
>         -DWITH_PYTHON=ON \
>         -DWITH_SVGCAIRO=ON \
>         -DWITH_ORACLESPATIAL=ON \
>         -DWITH_HARFBUZZ=0 \
>         -DWITH_FRIBIDI=0 \
>         -DWITH_FCGI=0 \
>          >../configure.out.txt
> configure.out:
> -- The C compiler identification is GNU 4.3.4
> -- The CXX compiler identification is GNU 4.3.4
> -- Check for working C compiler: /usr/bin/cc
> -- Check for working C compiler: /usr/bin/cc -- works
> -- Detecting C compiler ABI info
> -- Detecting C compiler ABI info - done
> -- Check for working CXX compiler: /usr/bin/c++
> -- Check for working CXX compiler: /usr/bin/c++ -- works
> -- Detecting CXX compiler ABI info
> -- Detecting CXX compiler ABI info - done
> -- Looking for strrstr
> -- Looking for strrstr - not found
> -- Looking for strcasecmp
> -- Looking for strcasecmp - found
> -- Looking for strcasestr
> -- Looking for strcasestr - found
> -- Looking for strdup
> -- Looking for strdup - found
> -- Looking for strlcat
> -- Looking for strlcat - not found
> -- Looking for strlcpy
> -- Looking for strlcpy - not found
> -- Looking for strlen
> -- Looking for strlen - found
> -- Looking for strncasecmp
> -- Looking for strncasecmp - found
> -- Looking for vsnprintf
> -- Looking for vsnprintf - found
> -- Looking for lrintf
> -- Looking for lrintf - found
> -- Looking for lrint - found
> -- Looking for dlfcn.h
> -- Looking for dlfcn.h - found
> -- Performing Test HAVE_SYNC_FETCH_AND_ADD
> -- Performing Test HAVE_SYNC_FETCH_AND_ADD - Success
> -- Found ZLIB: /usr/lib64/libz.so (found version "1.2.7")
> -- Found PNG: /usr/lib64/libpng.so (found version "1.2.31")
> -- Found JPEG: /usr/lib64/libjpeg.so
> -- Found Freetype: /usr/lib64/libfreetype.so
> -- Found PROJ: /usr/lib64/libproj.so
> -- Looking for iconv
> -- Looking for iconv - found
> -- Found iconv library:
> -- Found PkgConfig: /usr/bin/pkg-config (found version "0.23")
> -- checking for module 'cairo'
> --   found cairo, version 1.8.8
> -- Found CAIRO: /usr/lib64/libcairo.so
> -- Found ORACLE:
> /home/oracle/app/oracle/product/12.1.0/client_1/lib/libclntsh.so;/home/oracle/app/oracle/product/12.1.0/client_1/lib/libocci.so;/home/oracle/app/oracle/product/12.1.0/client_1/lib/libnnz12.so
> -- Found GEOS: /usr/lib64/libgeos_c.so
> -- Found POSTGRESQL: /usr/lib64/libpq.so
> -- Looking for PQserverVersion in pq
> -- Looking for PQserverVersion in pq - found
> -- Found GDAL: /opt/gdal-trunk/lib/libgdal.so
> -- Found SVG: /usr/local/lib/libsvg.so
> -- Found SVGCAIRO: /usr/local/lib/libsvg-cairo.so
> -- Found CURL: /usr/lib64/libcurl.so (found version "7.19.7")
> -- Found LibXml2: /usr/lib64/libxml2.so (found version "2.7.6")
> -- Performing Test GIF_GifFileType_UserData
> -- Performing Test GIF_GifFileType_UserData - Success
> -- Found GIF: /usr/lib64/libgif.so (found version "4")
> -- Found SWIG: /usr/bin/swig (found version "1.3.36")
> -- Found PythonInterp: /usr/bin/python (found version "2.6.9")
> -- * Summary of configured options for this build
> --  * Mandatory components
> --   * png: /usr/lib64/libpng.so
> --   * jpeg: /usr/lib64/libjpeg.so
> --   * freetype: /usr/lib64/libfreetype.so
> --  * Optional components
> --   * GDAL: /opt/gdal-trunk/lib/libgdal.so
> --   * OGR: /opt/gdal-trunk/lib/libgdal.so
> --   * GIF: /usr/lib64/libgif.so
> --   * MYSQL: disabled
> --   * FRIBIDI: disabled
> --   * HARFBUZZ: disabled
> --   * CAIRO: /usr/lib64/libcairo.so
> --   * SVGCAIRO: /usr/local/lib/libsvg-cairo.so
> --   * RSVG: disabled
> --   * CURL: /usr/lib64/libcurl.so
> --   * PROJ: /usr/lib64/libproj.so
> --   * PIXMAN: disabled
> --   * LIBXML2: /usr/lib64/libxml2.so
> --   * POSTGIS: /usr/lib64/libpq.so
> --   * GEOS: /usr/lib64/libgeos_c.so
> --   * FastCGI: disabled
> --   * Oracle Spatial:
> --   * Exempi XMP: disabled
> --  * Optional features
> --   * WMS SERVER: ENABLED
> --   * WFS SERVER: ENABLED
> --   * WCS SERVER: ENABLED
> --   * SOS SERVER: ENABLED
> --   * WMS CLIENT: ENABLED
> --   * WFS CLIENT: ENABLED
> --   * ICONV: ENABLED
> --   * Thread-safety support: disabled
> --   * KML output: disabled
> --   * Z+M point coordinate support: disabled
> --   * XML Mapfile support: disabled
> --  * Mapscripts
> --   * Python: ENABLED
> --   * PHP: ENABLED
> --   * PERL: disabled
> --   * RUBY: disabled
> --   * JAVA: disabled
> --   * C#: disabled
> --   * V8 Javascript: disabled
> --   * Apache Module (Experimental): disabled
> -- Will install files to /usr/local
> -- Will install libraries to /usr/local/lib
> -- Configuring incomplete, errors occurred!
> Is this related to disabling Harfbuzz or Fribidi? I understood that Harfbuzz
> is not needed unless for special languages character rendering?
> Thanks, Michael
> 2016-06-24 8:36 GMT+02:00 thomas bonfort <thomas.bonfort at gmail.com>:
>> Matthew,
>> What configure flags did you use to build harfbuzz? What harfbuzz
>> version are you using?
>> thomas
>> On 21 June 2016 at 20:41, Cechini, Matthew F. (GSFC-423.0)[Science
>> Systems & Applications, Inc.] <matthew.f.cechini at nasa.gov> wrote:
>> > As it turns out, the issue is Harfbuzz:
>> > In the pre-compile checks, I see this:
>> > -- checking for module 'harfbuzz>=0.9.18'
>> > --   package 'harfbuzz>=0.9.18' not found
>> > -- Found HarfBuzz: /usr/local/include/harfbuzz
>> > Seems ok, it didn’t find an installed RPM/package, but it finds the
>> > directory where I build and installed manually.
>> > But the problem then is that there is a missing header file from
>> > Harfbuzz:
>> > In file included from
>> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c:32:
>> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.h:15:20: error:
>> > hb-ft.h: No such file or directory
>> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c: In function
>> > 'msFreeFontCache':
>> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c:82: warning:
>> > implicit declaration of function 'hb_font_destroy'
>> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c:84: warning:
>> > implicit declaration of function 'hb_font_funcs_destroy'
>> > I see that particular header file in the src directory, from which `make
>> > install` is run for harfbuzz… but it’s not “installed”.  I can’t seem to
>> > find an RPM for Centos 6, so building from source seems to be the path I
>> > have to follow.
>> > Matt
>> > Matthew Cechini
>> > Contractor, Science Systems and Applications, Inc.
>> > NASA GIBS Systems/Software Engineer
>> > 410.205.6272
>> > From: Thomas Gratier <osgeo.mailinglist at gmail.com>
>> > Date: Tuesday, June 21, 2016 at 12:30 PM
>> > To: Matthew Cechini <matthew.f.cechini at nasa.gov>
>> > Cc: "mapserver-users at lists.osgeo.org" <mapserver-users at lists.osgeo.org>
>> > Subject: Re: [mapserver-users] Building Mapserver - missing strlcat...
>> > methods
>> > Hi,
>> > "build map server 7.0.1 on linux": distro, architecture?
>> > You should look at
>> > https://github.com/mapserver/mapserver/blob/branch-7-0/.travis.yml to
>> > find
>> > out more about MapServer deps.
>> > Cheers
>> > Thomas Gratier
>> > 2016-06-20 22:35 GMT+02:00 Cechini, Matthew F. (GSFC-423.0)[Science
>> > Systems
>> > & Applications, Inc.] <matthew.f.cechini at nasa.gov>:
>> >> I’m attempting to build map server 7.0.1 on linux and am getting the
>> >> following errors.  I’m sure I’m missing some dependency… but google has
>> >> failed me to figure it out.  Help?
>> >> -- Looking for PQserverVersion in pq - not found
>> >> -- Looking for pthread_create - not found
>> >> -- Looking for pthread_create in pthreads - not found
>> >> Matt
>> >> Matthew Cechini
>> >> 410.205.6272
>> >> _______________________________________________
>> >> mapserver-users mailing list
>> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Michael Schulz
