[mapserver-users] Building Mapserver - missing strlcat... methods
Michael Schulz
mandschulz at googlemail.com
Fri Jun 24 02:31:01 PDT 2016
Hi Thomas,
nope, unfortunately not. Deleted everything, rerun cmake, still got the
same errors (strsstr, strlcat, strlcpy not found). This is one part of
CMakeError.log:
Determining if the function strrstr exists failed with the following output:
Change Dir: /usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeTmp
Run Build Command:"/usr/bin/gmake" "cmTryCompileExec1997038117/fast"
/usr/bin/gmake -f CMakeFiles/cmTryCompileExec1997038117.dir/build.make
gmake[1]: Entering directory
`/usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeTmp'
/usr/bin/cmake -E cmake_progress_report
/usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeTmp/CMakeFiles 1
Building C object
CMakeFiles/cmTryCompileExec1997038117.dir/CheckFunctionExists.c.o
/usr/bin/cc -DCHECK_FUNCTION_EXISTS=strrstr
-I/usr/local/src/mapserver-7.0.1/build/CMakeFiles/CMakeTmp/math.h -o
CMakeFiles/cmTryCompileExec1997038117.dir/CheckFunctionExists.c.o -c
/usr/share/cmake/Modules/CheckFunctionExists.c
Linking C executable cmTryCompileExec1997038117
/usr/bin/cmake -E cmake_link_script
CMakeFiles/cmTryCompileExec1997038117.dir/link.txt --verbose=1
CMakeFiles/cmTryCompileExec1997038117.dir/CheckFunctionExists.c.o -o
cmTryCompileExec1997038117 -rdynamic -lm
CMakeFiles/cmTryCompileExec1997038117.dir/CheckFunctionExists.c.o: In
function `main':
CheckFunctionExists.c:(.text+0x15): undefined reference to `strrstr'
collect2: ld gab 1 als Ende-Status zurück
gmake[1]: Leaving directory
gmake[1]: *** [cmTryCompileExec1997038117] Fehler 1
gmake: *** [cmTryCompileExec1997038117/fast] Fehler 2
... (this is similarly repeated for the other functions)
Thanks, Michael
2016-06-24 10:09 GMT+02:00 thomas bonfort <thomas.bonfort at gmail.com>:
> Try deleting everything in the build directory and starting again,
> might be a cmake cache problem...
> On 24 June 2016 at 10:07, Michael Schulz <mandschulz at googlemail.com>
> wrote:
> > Hi,
> > I have exactly the same issue here. Trying to build mapserver on SLES 11
> > SP4, I have disabled harfbuzz and fribidi:
> > cmake .. \
> > -DCMAKE_PREFIX_PATH=/opt/gdal-trunk \
> > -DWITH_CLIENT_WFS=ON \
> > -DWITH_CLIENT_WMS=ON \
> > -DWITH_CURL=ON \
> > -DWITH_SOS=ON \
> > -DWITH_PHP=ON \
> > -DWITH_PYTHON=ON \
> > -DWITH_SVGCAIRO=ON \
> > -DWITH_ORACLESPATIAL=ON \
> > -DWITH_HARFBUZZ=0 \
> > -DWITH_FRIBIDI=0 \
> > -DWITH_FCGI=0 \
> > >../configure.out.txt
> > configure.out:
> > -- The C compiler identification is GNU 4.3.4
> > -- The CXX compiler identification is GNU 4.3.4
> > -- Check for working C compiler: /usr/bin/cc
> > -- Check for working C compiler: /usr/bin/cc -- works
> > -- Detecting C compiler ABI info
> > -- Detecting C compiler ABI info - done
> > -- Check for working CXX compiler: /usr/bin/c++
> > -- Check for working CXX compiler: /usr/bin/c++ -- works
> > -- Detecting CXX compiler ABI info
> > -- Detecting CXX compiler ABI info - done
> > -- Looking for strrstr
> > -- Looking for strrstr - not found
> > -- Looking for strcasecmp
> > -- Looking for strcasecmp - found
> > -- Looking for strcasestr
> > -- Looking for strcasestr - found
> > -- Looking for strdup
> > -- Looking for strdup - found
> > -- Looking for strlcat
> > -- Looking for strlcat - not found
> > -- Looking for strlcpy
> > -- Looking for strlcpy - not found
> > -- Looking for strlen
> > -- Looking for strlen - found
> > -- Looking for strncasecmp
> > -- Looking for strncasecmp - found
> > -- Looking for vsnprintf
> > -- Looking for vsnprintf - found
> > -- Looking for lrintf
> > -- Looking for lrintf - found
> > -- Looking for lrint - found
> > -- Looking for dlfcn.h
> > -- Looking for dlfcn.h - found
> > -- Performing Test HAVE_SYNC_FETCH_AND_ADD
> > -- Performing Test HAVE_SYNC_FETCH_AND_ADD - Success
> > -- Found ZLIB: /usr/lib64/libz.so (found version "1.2.7")
> > -- Found PNG: /usr/lib64/libpng.so (found version "1.2.31")
> > -- Found JPEG: /usr/lib64/libjpeg.so
> > -- Found Freetype: /usr/lib64/libfreetype.so
> > -- Found PROJ: /usr/lib64/libproj.so
> > -- Looking for iconv
> > -- Looking for iconv - found
> > -- Found iconv library:
> > -- Found PkgConfig: /usr/bin/pkg-config (found version "0.23")
> > -- checking for module 'cairo'
> > -- found cairo, version 1.8.8
> > -- Found CAIRO: /usr/lib64/libcairo.so
> > -- Found ORACLE:
> /home/oracle/app/oracle/product/12.1.0/client_1/lib/libclntsh.so;/home/oracle/app/oracle/product/12.1.0/client_1/lib/libocci.so;/home/oracle/app/oracle/product/12.1.0/client_1/lib/libnnz12.so
> > -- Found GEOS: /usr/lib64/libgeos_c.so
> > -- Found POSTGRESQL: /usr/lib64/libpq.so
> > -- Looking for PQserverVersion in pq
> > -- Looking for PQserverVersion in pq - found
> > -- Found GDAL: /opt/gdal-trunk/lib/libgdal.so
> > -- Found SVG: /usr/local/lib/libsvg.so
> > -- Found SVGCAIRO: /usr/local/lib/libsvg-cairo.so
> > -- Found CURL: /usr/lib64/libcurl.so (found version "7.19.7")
> > -- Found LibXml2: /usr/lib64/libxml2.so (found version "2.7.6")
> > -- Performing Test GIF_GifFileType_UserData
> > -- Performing Test GIF_GifFileType_UserData - Success
> > -- Found GIF: /usr/lib64/libgif.so (found version "4")
> > -- Found SWIG: /usr/bin/swig (found version "1.3.36")
> > -- Found PythonInterp: /usr/bin/python (found version "2.6.9")
> > -- * Summary of configured options for this build
> > -- * Mandatory components
> > -- * png: /usr/lib64/libpng.so
> > -- * jpeg: /usr/lib64/libjpeg.so
> > -- * freetype: /usr/lib64/libfreetype.so
> > -- * Optional components
> > -- * GDAL: /opt/gdal-trunk/lib/libgdal.so
> > -- * OGR: /opt/gdal-trunk/lib/libgdal.so
> > -- * GIF: /usr/lib64/libgif.so
> > -- * MYSQL: disabled
> > -- * FRIBIDI: disabled
> > -- * HARFBUZZ: disabled
> > -- * CAIRO: /usr/lib64/libcairo.so
> > -- * SVGCAIRO: /usr/local/lib/libsvg-cairo.so
> > -- * RSVG: disabled
> > -- * CURL: /usr/lib64/libcurl.so
> > -- * PROJ: /usr/lib64/libproj.so
> > -- * PIXMAN: disabled
> > -- * LIBXML2: /usr/lib64/libxml2.so
> > -- * POSTGIS: /usr/lib64/libpq.so
> > -- * GEOS: /usr/lib64/libgeos_c.so
> > -- * FastCGI: disabled
> > -- * Oracle Spatial:
> > -- * Exempi XMP: disabled
> > -- * Optional features
> > -- * WMS SERVER: ENABLED
> > -- * WFS SERVER: ENABLED
> > -- * WCS SERVER: ENABLED
> > -- * SOS SERVER: ENABLED
> > -- * WMS CLIENT: ENABLED
> > -- * WFS CLIENT: ENABLED
> > -- * ICONV: ENABLED
> > -- * Thread-safety support: disabled
> > -- * KML output: disabled
> > -- * Z+M point coordinate support: disabled
> > -- * XML Mapfile support: disabled
> > -- * Mapscripts
> > -- * Python: ENABLED
> > -- * PHP: ENABLED
> > -- * PERL: disabled
> > -- * RUBY: disabled
> > -- * JAVA: disabled
> > -- * C#: disabled
> > -- * V8 Javascript: disabled
> > -- * Apache Module (Experimental): disabled
> > -- Will install files to /usr/local
> > -- Will install libraries to /usr/local/lib
> > -- Configuring incomplete, errors occurred!
> > Is this related to disabling Harfbuzz or Fribidi? I understood that
> Harfbuzz
> > is not needed unless for special languages character rendering?
> > Thanks, Michael
> > 2016-06-24 8:36 GMT+02:00 thomas bonfort <thomas.bonfort at gmail.com>:
> >> Matthew,
> >> What configure flags did you use to build harfbuzz? What harfbuzz
> >> version are you using?
> >> thomas
> >> On 21 June 2016 at 20:41, Cechini, Matthew F. (GSFC-423.0)[Science
> >> Systems & Applications, Inc.] <matthew.f.cechini at nasa.gov> wrote:
> >> > As it turns out, the issue is Harfbuzz:
> >> > In the pre-compile checks, I see this:
> >> > -- checking for module 'harfbuzz>=0.9.18'
> >> > -- package 'harfbuzz>=0.9.18' not found
> >> > -- Found HarfBuzz: /usr/local/include/harfbuzz
> >> > Seems ok, it didn’t find an installed RPM/package, but it finds the
> >> > directory where I build and installed manually.
> >> > But the problem then is that there is a missing header file from
> >> > Harfbuzz:
> >> > In file included from
> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c:32:
> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.h:15:20: error:
> >> > hb-ft.h: No such file or directory
> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c: In function
> >> > 'msFreeFontCache':
> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c:82: warning:
> >> > implicit declaration of function 'hb_font_destroy'
> >> > /home/vagrant/rpmbuild/BUILD/mapserver-7.0.1/fontcache.c:84: warning:
> >> > implicit declaration of function 'hb_font_funcs_destroy'
> >> > I see that particular header file in the src directory, from which
> `make
> >> > install` is run for harfbuzz… but it’s not “installed”. I can’t seem
> to
> >> > find an RPM for Centos 6, so building from source seems to be the
> path I
> >> > have to follow.
> >> > Matt
> >> > Matthew Cechini
> >> > Contractor, Science Systems and Applications, Inc.
> >> > NASA GIBS Systems/Software Engineer
> >> > 410.205.6272
> >> > From: Thomas Gratier <osgeo.mailinglist at gmail.com>
> >> > Date: Tuesday, June 21, 2016 at 12:30 PM
> >> > To: Matthew Cechini <matthew.f.cechini at nasa.gov>
> >> > Cc: "mapserver-users at lists.osgeo.org" <
> mapserver-users at lists.osgeo.org>
> >> > Subject: Re: [mapserver-users] Building Mapserver - missing strlcat...
> >> > methods
> >> > Hi,
> >> > "build map server 7.0.1 on linux": distro, architecture?
> >> > You should look at
> >> > https://github.com/mapserver/mapserver/blob/branch-7-0/.travis.yml to
> >> > find
> >> > out more about MapServer deps.
> >> > Cheers
> >> > Thomas Gratier
> >> > 2016-06-20 22:35 GMT+02:00 Cechini, Matthew F. (GSFC-423.0)[Science
> >> > Systems
> >> > & Applications, Inc.] <matthew.f.cechini at nasa.gov>:
> >> >> I’m attempting to build map server 7.0.1 on linux and am getting the
> >> >> following errors. I’m sure I’m missing some dependency… but google
> has
> >> >> failed me to figure it out. Help?
> >> >> -- Looking for PQserverVersion in pq - not found
> >> >> -- Looking for pthread_create - not found
> >> >> -- Looking for pthread_create in pthreads - not found
> >> >> Matt
> >> >> Matthew Cechini
> >> >> 410.205.6272
> >> >> _______________________________________________
> >> >> mapserver-users mailing list
> >> >> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> > Michael Schulz
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20160624/746d78b7/attachment-0001.html>
