[mapserver-users] A problem with the Run-time substitution
Janne Tuovinen
janne.tuovinen at menturagroup.com
Mon Nov 7 06:07:51 PST 2016
Thank you, but this doesn't work for me. The problem is that I want to
pass a string value to my database, but the MapServer doesn't allow that
and always passes the parameters value as an integer.
-Janne
11/7/2016, 3:33 PM, Burgholzer, Robert (DEQ) wrote:
> I believe that what you want is this:
> PROCESSING "NATIVE_FILTER=param in '%param%' "
> I have not used the processing directive, so can not be sure, but the above syntax would work in a QUERY.
> -----Original Message-----
> From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Janne Tuovinen
> Sent: Monday, November 07, 2016 7:36 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] A problem with the Run-time substitution
> Hi,
> I have a problem when I'm trying to pass a url-parameter to Postgis query's NATIVE_FILTER in my map file.
> My layer looks something like this:
> LAYER
> VALIDATION
> 'param' '.+'
> END
> DATA "shape from table"
> PROCESSING "NATIVE_FILTER=param in %param%"
> END # LAYER
> Here is some examples what I get when I try to pass some values:
> ...¶m=1000 = > (param in (1000))
> ...¶m='1000' = > (param in (%param%))
> What I like to have is: (param in ('1000'))
> Is there a way to this with the MapServer 7.0?
> Thank you,
> Janne
