[mapserver-users] A problem with the Run-time substitution
Burgholzer, Robert (DEQ) Robert.Burgholzer at deq.virginia.gov
Mon Nov 7 06:18:19 PST 2016
By includiong the single quotes in the PROCESING directive, doesn't that make your input evaluated as a string?  You example suggests that mapserver considers single quotes around the input to be bad and rejects it - but by putting single quotes in PROCESSING it should avoid that.
What does the expression look like when you tried to syntax I suggested?
-----Original Message-----
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Janne Tuovinen
Sent: Monday, November 07, 2016 9:08 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] A problem with the Run-time substitution
Thank you, but this doesn't work for me. The problem is that I want to pass a string value to my database, but the MapServer doesn't allow that and always passes the parameters value as an integer.
-Janne
11/7/2016, 3:33 PM, Burgholzer, Robert (DEQ) wrote:
> I believe that what you want is this:
>       PROCESSING "NATIVE_FILTER=param in '%param%' "
> I have not used the processing directive, so can not be sure, but the above syntax would work in a QUERY.
> Sent: Monday, November 07, 2016 7:36 AM
> Subject: [mapserver-users] A problem with the Run-time substitution
> Hi,
> I have a problem when I'm trying to pass a url-parameter to Postgis query's NATIVE_FILTER in my map file.
> My layer looks something like this:
>   LAYER
>       VALIDATION
>           'param' '.+'
>       END
>       DATA "shape from table"
>       PROCESSING "NATIVE_FILTER=param in %param%"
>    END # LAYER
> Here is some examples what I get when I try to pass some values:
> ...&param=1000   = > (param in (1000))
> ...&param='1000' = > (param in (%param%))
> What I like to have is: (param in ('1000'))
> Is there a way to this with the MapServer 7.0?
> Thank you,
> Janne
