[mapserver-users] A problem with the Run-time substitution
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Mon Nov 7 06:11:57 PST 2016
It should work like this, if it doesn't then we probably have a bug
PROCESSING "NATIVE_FILTER=ct in ('%param%')"
See also http://gis.stackexchange.com/questions/214899/in-operator-in-filter-in-my-mapfile/214921#214921
-Jukka Rahkonen-
Janne Tuovinen wrote:
Re: [mapserver-users] A problem with the Run-time substitution
> Thank you, but this doesn't work for me. The problem is that I want to pass a string value to my database, > but the MapServer doesn't allow that and always passes the parameters value as an integer.
> -Janne
11/7/2016, 3:33 PM, Burgholzer, Robert (DEQ) wrote:
> I believe that what you want is this:
>       PROCESSING "NATIVE_FILTER=param in '%param%' "
> I have not used the processing directive, so can not be sure, but the above syntax would work in a QUERY.
> -----Original Message-----
> From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org]
> On Behalf Of Janne Tuovinen
> Sent: Monday, November 07, 2016 7:36 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] A problem with the Run-time substitution
> Hi,
> I have a problem when I'm trying to pass a url-parameter to Postgis query's NATIVE_FILTER in my map file.
> My layer looks something like this:
>   LAYER
>       VALIDATION
>           'param' '.+'
>       END
>       DATA "shape from table"
>       PROCESSING "NATIVE_FILTER=param in %param%"
>    END # LAYER
> Here is some examples what I get when I try to pass some values:
> ...&param=1000   = > (param in (1000))
> ...&param='1000' = > (param in (%param%))
> What I like to have is: (param in ('1000'))
> Is there a way to this with the MapServer 7.0?
> Thank you,
> Janne
