[mapserver-users] Converting a v5.6 CGI call to v6.0
Lime, Steve D (MNIT) Steve.Lime at state.mn.us
Wed Nov 9 13:32:35 PST 2016
Do you get an actual MapServer error? It sounds like you made the right changes relative to the URL.
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Joel Benford
Sent: Wednesday, November 09, 2016 10:17 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Converting a v5.6 CGI call to v6.0
Hello everybody,
I am maintaining a system for a customer that links to mapserver -- we're not mapserver users, they are.
Some time back, when they used mapserver v5.6, we put a partial mapserver CGI url in one of their configuration files. The idea was that they could edit it if they ever needed to in future, e.g. if they changed sever location for mapserver. They later upgraded to mapserver 6.0, but cjust changing the target server failed.
The original query substring was along the lines of:
http://someserver.ourcustomer.co.uk/MapServer/cgi-bin5.6/mapserv.exe?map=D:\Maps\CCC\Intranet52\_MapServerConfig\Surveys.map_AND_mode=ITEMNQUERYMAP_AND_qlayer=Buildings_AND_map.layer%5bBuildings%5d=TEMPLATE+'_MapServerTemplates\Buildings_fields.xml'_AND_qitem=SHORT_CODE_EMS_AND_qstring=  {application adds the rest here depending on what the user wants on that invocation}
I looked at the 5.6 to 6.0 migration guide at http://www.mapserver.org/MIGRATION_GUIDE.html#mapserver-5-6-to-6-0-migration and in the CGI section it says:
    All of the query map related modes (e.g. NQUERYMAP, ITEMQUERYMAP, etc...) have been removed in favor of using the "qformat" parameter. That parameter takes an output format name or mime/type as a value and uses that to process a set of query results. For example:
...&mode=nquerymap&... would become ...&mode=nquery&qformat=png24&...
So I tried a simple substitution in line with that and changed our substring to:
http:// someserver.ourcustomer.co.uk /mapserv6/cgi-bin6.0/mapserv.exe?map=D:\Maps\CCC\Intranet52\_MapServerConfig\Surveys.map_AND_mode=ITEMNQUERY_AND_qformat=png24_AND_qlayer=Buildings_AND_map.layer%5bBuildings%5d=TEMPLATE+'_MapServerTemplates\Buildings_fields.xml'_AND_qitem=SHORT_CODE_EMS_AND_qstring<http://vishare.cardiff.gov.uk/mapserv6/cgi-bin6.0/mapserv.exe?map=D:\Maps\CCC\Intranet52\_MapServerConfig\Surveys.map_AND_mode=ITEMNQUERY_AND_qformat=png24_AND_qlayer=Buildings_AND_map.layer%5bBuildings%5d=TEMPLATE+'_MapServerTemplates\Buildings_fields.xml'_AND_qitem=SHORT_CODE_EMS_AND_qstring>=
...i.e. I changed the target from the 5.6 to 6.0 server and changed "mode=ITEMNQUERYMAP" to "mode=ITEMNQUERY_AND_qformat=png24"
This did not meet with success, I got a "Parameter is not valid" error with the following stack trace:
[ArgumentException: Parameter is not valid.]
System.Drawing.Image.FromStream(Stream stream, Boolean useEmbeddedColorManagement, Boolean validateImageData) +1067179
System.Drawing.Image.FromStream(Stream stream) +8
SurveysReporting.ReportProvider.GenerateReport(ReportName rnName, String szShortCode) +4371
Reports_Preview.Page_Load(Object sender, EventArgs e) +374
System.Web.Util.CalliHelper.EventArgFunctionCaller(IntPtr fp, Object o, Object t, EventArgs e) +14
System.Web.Util.CalliEventHandlerDelegateProxy.Callback(Object sender, EventArgs e) +35
System.Web.UI.Control.OnLoad(EventArgs e) +99
System.Web.UI.Control.LoadRecursive() +50
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +627
Superficially, this error doesn't seem to have much to do with the parameter I changed.
At this point, I would like to ask some more experienced mapserver users a few questions:
1.       Is my substitution of "mode=ITEMNQUERYMAP" to "mode=ITEMNQUERY_AND_qformat=png24" a viable solution in itself?
2.       Does anything else in the amended query substring above jump out as incorrect in v6.0?
3.       Does the error message received look like the sort of thing that would apply to the rest of the CGI query, i.e. the stuff that's added on the end to suit the specific user request?
I'm really hoping for 2, because otherwise I'll have to get our legacy application running and then learn mapserver syntax to change what it's sending.
Thanks in advance for any help or advice.
Joel Benford
The information contained in or attached to this message is the responsibility of the sender and is meant for the confidential use of the intended recipients. It does not necessarily represent the position of Aligned Assets. If you are not an intended recipient you are notified that you have received this communication in error and that review, dissemination or copying of this communication is prohibited.
If you have received this in error, please notify us.
Aligned Assets Limited
Unit 5
River Court
Albert Drive
Sheerwater
Woking
GU21 5RP
Company Registration No: 4610724
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161109/ab8984b2/attachment-0001.html>
