[mapserver-users] GetFeatureInfo layout in plain text
Schepers, Benjamin schepers at rvr-online.de
Thu Nov 10 07:44:43 PST 2016
Hi Yves,
from my point of view this isn't possible, templating in mapserver-WMS just works for HTML.
You would need an wrapper-script, which does some postprocessing/transforming with GFI-response (text) from mapserver - could be done with bash/perl/python/php whatever, maybe mapscript-engine (I'm not into this) or within Apache-Webserver (mod_sed ;-) ).
Most structured way would be rewriting GFI-request from text-format to gml-format within the receiving webserver, directing this request to mapserver (which would create gml-response), directing mapserver-response to xml-processor and transform to whatever you want and then let webserver deliver the response to the client...
Edit:
Jörg was faster, because of having a phonecall from one of his coworkers ;-) and also my post was blocked by the mailing-list caused by an attachment ☹ ,sorry, Jeff.
ArcGIS Desktop 10.x does show html-GFI, see attachment (image is clipped, it is a screenshot from within ArcGIS):
http://pasteboard.co/pANcOnMbD.jpg
Ben
Mit freundlichen Grüßen
Im Auftrag
Benjamin Schepers
Luftbild und Geoinformationssysteme
Kronprinzenstraße 6
45128 Essen
Fon: +49 201 2069-232
Fax: +49 201 2069-500
[cid:image001.jpg at 01D23B71.BDC6EEC0]
Die Regionaldirektorin
Kronprinzenstraße 35
45128 Essen
Zentrale: +49 (0) 201 2069-0
Fax: +49 (0) 201 2069-500
www.metropoleruhr.de
Postfach 10 32 64
45032 Essen
Steuernummer: RVR 112/5797/0116
USt.-ldNr.: DE 173867500
Diese E-Mail koennte vertrauliche und/oder rechtlich geschuetzte Informationen enthalten.
Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und vernichten Sie diese Mail.
Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser E-Mail sind nicht gestattet.
This e-mail may contain confidential and/or privileged information.
If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and destroy this e-mail.
Any unauthorised copying, disclosure or distribution of the material in this e-mail is strictly forbidden.
Von: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] Im Auftrag von Yves Jacolin
Gesendet: Donnerstag, 10. November 2016 13:03
An: Jörg Thomsen (WhereGroup)
Cc: mapserver-users
Betreff: Re: [mapserver-users] GetFeatureInfo layout in plain text
humm, good point, I need to check the output request from ArcGIS. The users said that for other service they get a table, so probably an html format.
Thanks,
Y.
2016-11-10 12:59 GMT+01:00 Jörg Thomsen (WhereGroup) <joerg.thomsen at wheregroup.com<mailto:joerg.thomsen at wheregroup.com>>:
so, what do you have to style? Perhaps you could create a text-format
output with templates to create a sort of ascii-tables, you don't have
to use html-tags within the templates. But in this case the request has
to be format=text/html.
Jörg
Am 10.11.2016 um 12:39 schrieb Yves Jacolin:
> Thanks Jörg,
> Unfortunately I should use text format as ArcGIS desktop don't support other
> format (to be confirmed).
> Y.
> On Thursday, November 10, 2016 11:49:49 Jörg Thomsen wrote:
>> Hi Yves,
>> text/plain is text/plain, no layout. The Mapserver-templates work with
>> html-format. Another way could be using the xml-output and styling it
>> with xslt. But you can enable the html-output using templates with
>> mapserver and it still will be possible to send text/plain requests.
>> Templating ist easy and powerful, so to answer your question: yes, read
>> the templating chapter. You'll find a short introduction in the old
>> tutorial: http://demo.mapserver.org/tutorial/section3.html (example 3.1)
>> Jörg
>> Am 10.11.2016 um 11:16 schrieb Yves Jacolin:
>>> Hello,
>>> I have to setup a text format for a WMS' GetFeatureInfo service. I would
>>> like to know if it is possible to change the layout using a template.
>>> My first test was not working so any feedback is welcome. The
>>> documentation
>>> said that the user should read the templating chapter so I guess this is
>>> possible.
>>> Any confirmation?
>>> Y.
>> Viele Grüße,
>> Jörg Thomsen
Viele Grüße,
Jörg Thomsen
Where2B Konferenz 2016
15. Dezember 2016 in Bonn
www.where2b-conference.com<http://www.where2b-conference.com>
Jörg Thomsen
WhereGroup GmbH & Co. KG
Gillweg 3
14193 Berlin
Germany
Fon: +49 (0)30 / 5130 278 74<tel:%2B49%20%280%2930%20%2F%205130%20278%2074>
Fax: +49 (0)30 / 89 09 53 11<tel:%2B49%20%280%2930%20%2F%2089%2009%2053%2011>
www.wheregroup.com<http://www.wheregroup.com>
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
mapserver-users mailing list
mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
http://lists.osgeo.org/mailman/listinfo/mapserver-users
Responsable Formation et Support
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel (France) : +33 4 58 48 20 43 (new !)
Tel (Suisse) : +41 21 619 10 43
Mob. : +33 6 18 75 42 21
Fax : 04 79 70 15 81
Mail : yves.jacolin at camptocamp.com<mailto:yves.jacolin at camptocamp.com>
http://www.camptocamp.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161110/3863641c/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161110/3863641c/attachment-0001.jpg>
