[mapserver-users] MAP_RESOLUTION parameter
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Wed Nov 16 02:18:39 PST 2016
There was some discussion 5 years ago https://lists.osgeo.org/pipermail/mapserver-users/2011-June/069136.html but obviously I did not made the documentation ticket.
Because MAP_RESOLUTION can be used without having it in the mapfile I feel that it should be documented in http://mapserver.org/ogc/wms_server.html as a vendor parameter. For Mapserver CGI the place could be http://mapserver.org/cgi/controls.html. MAP.RESOLUTION and MAP.DEFRESOLUTION is the syntax to use as cgi controls.
The default value is 72 and that is documented in http://mapserver.org/development/rfc/ms-rfc-55.html.
-Jukka Rahkonen-
Lähettäjä: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Marco Afonso
Lähetetty: 16. marraskuuta 2016 11:47
Vastaanottaja: mapserver <mapserver-users at lists.osgeo.org>
Aihe: [mapserver-users] MAP_RESOLUTION parameter
Hello,
By using OpenLayers 3 and WMS I found a really usefull parameter: MAP_RESOLUTION.
It's very important to request images with higher resolution for printing.
I did some search about it's documentation but I can't find any.
I found references to MAP.RESOLUTION and MAP.DEFRESOLUTION but not about MAP_RESOLUTION.
Please where I can find documentation about this parameter.
What is the default value assumed if MAP_RESOLUTION is missing on the WMS request?
Thank you!
Regards,
Marco Afonso
http://goo.gl/ZDtQjm
[Lähettäjä poisti kuvan.]
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161116/c68e2429/attachment.html>
Type: image/jpeg
Desc: ~WRD000.jpg
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161116/c68e2429/attachment.jpg>
