[mapserver-users] Can't get capabilities xml error message
mathias cunault
mathias.cunault at inrap.fr
Thu Nov 24 00:31:42 PST 2016
thanks for advice. WMS is back again, at last !
2016-11-23 16:55 GMT+01:00 Jeff McKenna <jmckenna at gatewaygeomatics.com>:
> Another step in my debugging is always, for problem database layers, is to
> add an EXTENT parameter inside that same layer (which you get from an
> ogrinfo command).
> Also, if everything works (commandline, manual requests in browser), then
> I always use a tool like Fiddler to get the exact (problem) request that is
> being generated by QGIS.
> Anyway, thanks again for using MS4W for sharing your spatial information.
> Be sure to contact me and help support MS4W, as I see that it is very
> important for your needs.
> Thanks again,
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
> On 2016-11-23 11:48 AM, mathias cunault wrote:
>> I did what you said : I copy and paste layer by layer from the old
>> mapfile to a new one, and test each time. I did not make any
>> modification (as far as i know). Now I can get the capabilities in FF !
>> Thanks.
>> Now I have the list of layers in QGIS. But I can't load them : it seems
>> to have a problem of connection with PostGIS. Log error says :
>> Error executing SQL: (connection pointer is NULL
>> ) in msPostGISLayerGetExtent()[Wed Nov 23 16:33:27 2016].216000
>> msPostGISLayerGetExtent(): General error message. Error executing SQL.
>> Check server logs.
>> I guess that the logs in the message are PostGIS ones ?
>> 2016-11-23 15:10 GMT+01:00 Jeff McKenna <jmckenna at gatewaygeomatics.com
>> <mailto:jmckenna at gatewaygeomatics.com>>:
>> In that tiny mapfile (one layer), I would also remove any special
>> characters and numbers from any of your strings in that small
>> mapfile (so no accents, numbers, spaces in any NAME parameters, and
>> remove any special characters from the wms_title metadata or
>> elsewhere). Working with that copied mapfile and removing all those
>> things helps me debug always - then later I can go back to the full
>> mapfile, get that working at the commandline, then test with a
>> manual request in the browser, and finally test in a client such as
>> QGIS or OpenLayers.
>> -jeff
>> Jeff McKenna
>> http://www.gatewaygeomatics.com/ <http://www.gatewaygeomatics.com/>
>> On 2016-11-23 9:48 AM, Jeff McKenna wrote:
>> Hi,
>> Regarding your issue, here is my advice for how I always debug
>> such a
>> situation:
>> - I narrow down the mapfile until I am able to have the
>> smallest/shortest mapfile that still generates the error (one
>> layer,
>> simple classification)
>> - once I have that tiny mapfile, then examine that one problem
>> layer
>> (most times I also change the data in that layer, from something
>> like a
>> PostGIS connection to a local shapefile, and see if that changes
>> anything)
>> - for OGC/WMS requests, I will run the request directly from the
>> MS4W
>> commandline, such as:
>> setenv.bat
>> mapserv -nh
>> QUERY_STRING="map=D:\ms4w\blah.map&SERVICE=wms&REQUEST=GetCa
>> pabilities"
>> getcap.xml
>> And open that generated xml file to check for any errors or
>> "WARNING"s
>> in the response.
>> Thank you for the positive feedback from you that MS4W is
>> working great
>> for you and your clients.
>> -jeff
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.
>> osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> <http://lists.osgeo.org/mailman/listinfo/mapserver-users>
>> /Mathias Cunault/
>> /chargé d’opération et de recherche
>> ///Inrap Tours - /148 av. Maginot
>> 37000 TOURS
>> 06 32 05 98 96
>> _mathias.cunault at inrap.fr <mailto:mathias.cunault at inrap.fr>_/
>> www.inrap.fr <http://www.inrap.fr>
>> abonnez-vous à la lettre d'information de l'Inrap :
>> http://www.inrap.fr/newsletter.php
>> Darth Mathias : "Topology is a pathway to many abilities some consider
>> to be unnatural"
>> Padwan : "Is it possible to learn this power ?"
>> Darth Mathias : "Not from an archaeologist !"
*Mathias Cunault*
*chargé d’opération et de recherche*
*Inrap Tours - 148 av. Maginot37000 TOURS06 32 05 98
96mathias.cunault at inrap.fr <mathias.cunault at inrap.fr>*
www.inrap.fr
Darth Mathias : "Topology is a pathway to many abilities some consider to
be unnatural"
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161124/0990a69c/attachment.html>
