[mapserver-users] New Raster MapServer Tutorial
Schepers, Benjamin
schepers at rvr-online.de
Sun Nov 27 23:14:26 PST 2016
Hi Seth,
nice work!
To your questions:
- PNG24/32: lossless, so no quality-parameter, just compression efficiency (comparable to ZIP-Compression; size vs. needed time) [FORMATOPTION “ZLEVEL=n”]
- PNG8: also lossless compression, but with color-depth-reduction (quantization), if you have data with more than 256 colors – this can/will be lossy; also holds transparency-information (look-up-table for defined colors can have rgba-values)
- JPEG: IMHO the optimum for base-layers because of it’s small size and good performance (at least, if the base layer is not optimized with reduced color – png8); optimum for aerial images and “noisy” data; quality can be controlled as show downwards…
- GeoTIFF: good solution, if you’d like to use the wms as “download-service” – images then hold complete GeoTIFF-Header (was buggy with older mapserver/GDAL-versions, but seems OK for now)
Transparency can be controlled in different manners (in mapfile or in original data), at least these, please correct me:
Mapfile:
- LAYER-MASK (polygon-layer, outer area is transparent)
- LAYER-OFFSITE (mapfile-NoData-value)
Data-side:
- NoData-value (e.g. GTIFF-Header)
- Alpha/Transparency (e.g. GTIFF – per Pixel)
- Mask-layer inside data (separate GDAL-special pixel-mask-layer inside GTIFF for full transparency; useful in combination with GTIFF inside JPEG-compression, because JPEG can’t hold alpha-channel and NoData doesn’t work calculable caused by lossy compression)
If compiling GDAL and mapserver by your own, then using libjpeg-turbo instead of libjpeg brings some extra pieces of performance, specially when dealing with large amounts of image-data.
You can define/modify default-formats and add special GDAL compression-options with ‘ FORMATOPTION “KEY=VALUE” ’, do not forget to add format to formatlist:
http://pastebin.com/1YztvEcw
Ben
Luftbild und Geoinformationssysteme
Kronprinzenstraße 6
45128 Essen
Fon: +49 201 2069-232
Fax: +49 201 2069-500
schepers at rvr-online.de<mailto:schepers at rvr-online.de>
Die Regionaldirektorin
Kronprinzenstraße 35
45128 Essen
Zentrale: +49 (0) 201 2069-0
Fax: +49 (0) 201 2069-500
www.metropoleruhr.de<http://www.metropoleruhr.de>
Postfach 10 32 64
45032 Essen
Steuernummer: RVR 112/5797/0116
USt.-ldNr.: DE 173867500
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20161128/d79e65b9/attachment-0001.html>
