[mapserver-users] mapcache, datasources examples
Jukka Sirviö Jukka.Sirvio at mipro.fi
Thu Sep 8 05:37:58 PDT 2016
Hello,
Ok, I was not able to successfully initialize mapcache with desired functionality, despite of considerable amount of efforts submitted. That's why I was forced to choose MapProxy -option according Travis Kirstine's suggestion in "[mapserver-users] mapcache question" on "Wednesday, August 24, 2016 1:14 PM". After couple of days in operation, MapProxy seems to work as expected, also with this kind of 'advanced' configuration. Additional benefit is, that there is quite a lot of examples to begin work with MapProxy.
ps. my pull request #156 concerning MapCache documentation is still open.
Best regards:
Jukka
-----Alkuperäinen viesti-----
Lähettäjä: Jukka Sirviö
Lähetetty: 31. elokuuta 2016 12:36
Vastaanottaja: 'thomas bonfort'
Kopio: mapserver-users at lists.osgeo.org
Aihe: VS: [mapserver-users] mapcache, datasources examples
thanks, I did make a pull request #156 concerning discussed documentation.
after adding the new source to mapcache.xml, httpd is starting ok, and mapcache is able to read the new gdal_wmts.xml file,  but the demo app is not responding anymore.
Lähettäjä: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Lähetetty: 30. elokuuta 2016 15:38
Vastaanottaja: Jukka Sirviö
Aihe: Re: [mapserver-users] mapcache, datasources examples
there is not documentation yet, feel free to submit some...
this should get you started:
<source type="gdal" name="foo">
  <data>/path/to/gdal/file</data>
</source>
On 30 August 2016 at 14:34, Jukka Sirviö <Jukka.Sirvio at mipro.fi> wrote:
> http://mapserver.org/mapcache/sources.html
> It would be nice to have some examples for example on GDAL (wmts) datasource on above page? currently only WMS datasource is included.
> Would it?
> ________________________________
> Tämä sähköpostiviesti (liitteineen) saattaa sisältää luottamuksellista
> tietoa, joka on tarkoitettu vain vastaanottajalleen. Jos et ole oikea
> vastaanottaja, ilmoita viestin lähettäjälle tapahtuneesta virheestä ja
> tuhoa viesti välittömästi. Viestin luvaton julkaiseminen, kopioiminen, jakelu tai muu käyttö tai toimenpiteisiin ryhtyminen sen perusteella on ehdottomasti kielletty.
> This message (including any attachments) may contain confidential
> information intended for the person or entity to which it is
> addressed. If you are not the intended recipient, notify the sender
> and delete this message immediately. Notice that disclosing, copying, distributing or any other use of the message and its information, or taking any action based on it, is strictly prohibited.
