[mapserver-users] Georeferencing a raster without worldfile
Trond Michelsen
trondmm-mapserver+2017 at crusaders.no
Fri Dec 1 08:19:14 PST 2017
Hi.
I'm using mapserver 7.0.0
I have about 250.000 raster images that I want to serve through
mapserver. They are all 1195x1550 pixels, and they all cover the exact
same area (UTM33N -75000,6450000,1120000,8000000). All images has a
resolution of 1km per pixel.
I also have a worldfile that works:
--8<--
1000
0.0
0.0
-1000
-75000
8000000
--8<--
What I want to avoid, is to have one worldfile for each of the 250.000 files.
I have tried to use a processing directive, like the documentation says:
--8<--
WORLDFILE=<file>
Specifies an alternative world file (for georeferencing). If a
path only is specified, the base name of the dataset will be
appended. The suffix (.wld / .tfw / ...) can be omitted.
Example:
PROCESSING "WORLDFILE=/path/"
or
PROCESSING "WORLDFILE=/path/file.wld"
or
PROCESSING "WORLDFILE=/path/file"
--8<--
But adding
PROCESSING "WORLDFILE=/path/to/my/worldfile.wld"
to my mapfile has, as far as I can tell, absolutely no effect.
The projection on the layer is defined like this:
PROJECTION
"+init=epsg:32633"
END
If I change that to
PROJECTION
"+init=epsg:32633 +units=km"
END
My layer will turn up at 0,0,1195000,1550000 in EPSG:32633
In theory, if I added easting and northing to the projection definition, like this:
PROJECTION
"+init=epsg:32633 +units=km +x_0=-75000 +y_0=6450000"
END
It should position itself properly, but proj does not allow easting or
northing to the UTM projections.
The documetation also states:
--8<--
wms_extent
For Rasters served through WMS, MapServer can now use the
wms_extent metadata parameter to register the image. If a .wld
file cannot be found, MapServer will then look for the wms_extent
metadata parameter and use the extents of the image and the size
of the image for georegistration.
--8<--
However, if I add
METADATA
"wms_extent" "-75000 6450000 1120000 8000000"
END
to the layer, it has no effect.
So... What am I doing wrong? How do I get my files to show up where
they're supposed to?
Trond Michelsen
