[mapserver-users] Georeferencing a raster without worldfile
Fawcett, David (MNIT) david.fawcett at state.mn.us
Fri Dec 1 08:38:38 PST 2017
If these are .tif files, can you write the georeference info to internal metadata as a way to avoid a .tfw file?
-----Original Message-----
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Trond Michelsen
Sent: Friday, December 01, 2017 10:19 AM
To: Mapserver <mapserver-users at lists.osgeo.org>
Subject: [mapserver-users] Georeferencing a raster without worldfile
Hi.
I'm using mapserver 7.0.0
I have about 250.000 raster images that I want to serve through mapserver. They are all 1195x1550 pixels, and they all cover the exact same area (UTM33N -75000,6450000,1120000,8000000).  All images has a resolution of 1km per pixel.
I also have a worldfile that works:
--8<--
1000
0.0
0.0
-1000
-75000
8000000
--8<--
What I want to avoid, is to have one worldfile for each of the 250.000 files.
I have tried to use a processing directive, like the documentation says:
--8<--
WORLDFILE=<file>
    Specifies an alternative world file (for georeferencing). If a
    path only is specified, the base name of the dataset will be
    appended. The suffix (.wld / .tfw / ...) can be omitted.
    Example:
        PROCESSING "WORLDFILE=/path/"
         or
        PROCESSING "WORLDFILE=/path/file.wld"
         or
        PROCESSING "WORLDFILE=/path/file"
--8<--
But adding
PROCESSING "WORLDFILE=/path/to/my/worldfile.wld"
to my mapfile has, as far as I can tell, absolutely no effect.
The projection on the layer is defined like this:
  PROJECTION
    "+init=epsg:32633"
  END
If I change that to
  PROJECTION
    "+init=epsg:32633 +units=km"
  END
My layer will turn up at 0,0,1195000,1550000 in EPSG:32633
In theory, if I added easting and northing to the projection definition, like this:
  PROJECTION
    "+init=epsg:32633 +units=km +x_0=-75000 +y_0=6450000"
  END
It should position itself properly, but proj does not allow easting or northing to the UTM projections.
The documetation also states:
--8<--
wms_extent
    For Rasters served through WMS, MapServer can now use the
    wms_extent metadata parameter to register the image. If a .wld
    file cannot be found, MapServer will then look for the wms_extent
    metadata parameter and use the extents of the image and the size
    of the image for georegistration.
--8<--
However, if I add
  METADATA
    "wms_extent" "-75000 6450000 1120000 8000000"
  END
to the layer, it has no effect.
So... What am I doing wrong? How do I get my files to show up where they're supposed to?
Trond Michelsen
mapserver-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-users
