[mapserver-users] OFFSET and RAGECOLOR
Ivan Ogasawara ivan.ogasawara at gmail.com
Thu Dec 7 12:18:32 PST 2017
done! I don't know if this is the best way to do that .. but ..
this is my layer config:
        PROJECTION
         "init=epsg:4326"
       END
       METADATA
         "wms_title" "RIO_DE_JANEIRO"
         "wms_srs" "EPSG:4326 EPSG:3857"
         "wms_include_items" "all"
       END
       COMPOSITE
           OPACITY 70
       END # COMPOSITE
       # PROCESSING "KERNELDENSITY_NORMALIZATION=255"
       # PROCESSING "RANGE_COLORSPACE=HSL"
       CLASSITEM "[pixel]"
       CLASS
         NAME "class_hotcolors"
         EXPRESSION ([pixel] >= 1)
         STYLE
            RANGEITEM "style_hotcolors"
            COLORRANGE  1 0 0  255 0 0
            DATARANGE 1 8549
         END # STYLE
       END # CLASS
       CLASS
         NAME "class_background"
         EXPRESSION ([pixel] == 0)
         STYLE
            RANGEITEM "style_background"
            COLORRANGE  0 0 0  0 0 0
            DATARANGE 0 0
         END # STYLE
       END # CLASS
   END
My best regards,
Ivan
2017-12-07 15:56 GMT-04:00 Ivan Ogasawara <ivan.ogasawara at gmail.com>:
> Sorry .. actually is OFFSITE
> OFFSITE [r] [g] [b] | [hexadecimal string]
> Sets the color index to treat as transparent for raster layers.
>    r, g and b shall be integers [0..255]. To specify black pixels, the
>    following is used:
>    OFFSITE 0 0 0
> As in the mapfile sent.
> 2017-12-07 15:52 GMT-04:00 Ivan Ogasawara <ivan.ogasawara at gmail.com>:
>> I guess I misunderstood the offset parameter (actually before I added the
>> colorrange parameter, offset was disabled).
>> but after I've added the colorrange parameter, the background is not
>> transparent anymore ...
>> 2017-12-07 15:41 GMT-04:00 Ivan Ogasawara <ivan.ogasawara at gmail.com>:
>>> Hi Jukka,
>>> these are my map files, raster file and the image output.
>>> my best,
>>> Ivan
>>> 2017-12-07 2:36 GMT-04:00 Rahkonen Jukka (MML) <
>>> jukka.rahkonen at maanmittauslaitos.fi>:
>>>> Hi,
>>>> It is impossible to help you with so little details. Show us a
>>>> corresponding part of your mapfile and a small sample of data that can be
>>>> user for re-producing the error would be appreciated.
>>>> -Jukka Rahkonen-
>>>> Lähettäjä: Ivan Ogasawara <ivan.ogasawara at gmail.com>
>>>> Lähetetty: ‎7.‎12.‎2017 4:28
>>>> Vastaanottaja: mapserver-users at lists.osgeo.org
>>>> Aihe: [mapserver-users] OFFSET and RAGECOLOR
>>>> Dear all,
>>>> when I use style colorrange the offset directive doesn't work.
>>>> my mapserver install configurations is:
>>>> MapServer version 7.0.4 OUTPUT=PNG OUTPUT=JPEG OUTPUT=KML SUPPORTS=PROJ
>>>> SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=CAIRO SUPPORTS=SVG_SYMBOLS
>>>> SUPPORTS=RSVG SUPPORTS=ICONV SUP
>>>> PORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>>>> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
>>>> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUP
>>>> PORTS=GEOS INPUT=JPEG INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
>>>> any idea to resolve this problem?
>>>> my best regards,
>>>> Ivan
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20171207/ade81c37/attachment.html>
