[mapserver-users] mapserver with kml
Ivan Ogasawara
ivan.ogasawara at gmail.com
Thu Dec 14 08:35:32 PST 2017
Dear all, thanks :)
Carlo Ruiz,
> http://mapserver.org/input/vector/kml.html
Actually, in my case, the input should be shapefile and the outputs
gtiff,png and kml.
http://mapserver.org/output/kml_output.html
Jukka Rahkonen,
> I used version 1.3.0 so that the response will open into the browser
automatically.
Great! I changed to v 1.3.0 too
this is my new url request:
http://172.17.0.2/?map=/maps/dengue-Rio-de-Janeiro.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&LAYERS=RIO_DE_JANEIRO&STYLES=&CRS=CRS:84&BBOX=-43.7965385309,-23.0828926973,-43.0990394004,-22.7460202858&WIDTH=400&HEIGHT=300&FORMAT=kml
> Do you have KML in the list?
yes. Full GetCapabilities xml here: https://pastebin.com/z2myYc5m
> Did you just guess or is there somewhere wrong documentation about
metadata item you have tried # "wms_format" "image/png")
I saw it at some page ... but I think I haven't seen any difference (I
don't remember so well) .. so I commented this option.
> However, you must explicitly add KML into WMS outputformats in the
metadata. It seems that you have played with it because you have this line
commented out:
OK .. I added `wms_getmap_formatlist` parameter. I also added
`wms_formatlist` to metadata layer
I also change SRS=EPSG:4326 to CRS=CRS:84
Seth,
> Ivan's problem looks to be a projection issue only.
I also added crs:84 .. but the result is the same ..
KML by specification uses only a single projection, EPSG:4326 (
http://www.gdal.org/drv_kml.html)
My shapefile is defined as epsg:4326 too
The png output works fine ... maybe something in kml conversion is doing
wrong ...
The log about kml request is here: https://pastebin.com/iP4h0wXx
Ivan Ogasawara
2017-12-14 10:08 GMT-04:00 Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi>:
> Hi,
> Geoservers have KML output enabled by default so you can have a try with
> clients. Test-URL
> http://demo.geo-solutions.it/geoserver/wms?REQUEST=GetMap&
> SERVICE=WMS&VERSION=1.1.1&WIDTH=1373&HEIGHT=840&LAYERS=
> topp%3Astates&TRANSPARENT=TRUE&FORMAT=application/vnd.
> google-earth.kml+xml&BBOX=-124.731422,19.49461526802622,-
> 66.969849,54.83308673197378&SRS=EPSG:4326&STYLES=
> WMS 1.3.0 does not say anything about GetMap formats, just that they must
> appear in GetCapabilities, and all formats that appear in GetCapabilities
> must also be usable.
> -Jukka Rahkonen-
> *Lähettäjä:* Seth G [mailto:sethg at geographika.co.uk]
> *Lähetetty:* 14. joulukuuta 2017 14:56
> *Vastaanottaja:* Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>;
> mapserver-users at lists.osgeo.org
> *Aihe:* Re: [mapserver-users] mapserver with kml
> Interesting!
> From the WMS spec: "Graphic element formats include Scalable Vector
> Graphics (SVG; MIME type “image/svg+xml”) or Web Computer Graphics Metafile
> (WebCGM; MIME type “image/cgm;Version=4;ProfileId=WebCGM”) formats"
> I wonder how many WMS clients would handle KML as a WMS. As it is XML then
> it would't be accessible from another domain in a web client.
> Seth
> web:http://geographika.co.uk
> twitter: @geographika
> On Thu, Dec 14, 2017, at 10:42 AM, Rahkonen Jukka (MML) wrote:
> Hi Seth,
> KML is considered as an image format and it should work with WMS and with
> mode=map http://mapserver.gis.umn.edu/fr/development/rfc/ms-rfc-58.html
> It seems that KML output has not been developed much since the initial
> implementation.
> -Jukka Rahkonen-
> *Lähettäjä:* mapserver-users [mailto:mapserver-users-
> bounces at lists.osgeo.org <mapserver-users-bounces at lists.osgeo.org>] *Puolesta
> *Seth G
> *Lähetetty:* 14. joulukuuta 2017 10:03
> *Vastaanottaja:* mapserver-users at lists.osgeo.org
> Hi,
> Your output image looks like a projection issue. Google Maps use the
> espg:3857 projection, but your request is asking for SRS=epsg:4326, maybe
> try changing this?
> Also are you trying to return KML or display an image using KML as a data
> source? If you are trying to return KML you'd need to use WFS rather than
> WMS which only returns images.
> Seth
> On Thu, Dec 14, 2017, at 01:33 AM, Ivan Ogasawara wrote:
> Dear all,
> Anyone knows some tutorial to work with mapserver (wms) and kml?
> I am trying to do it .. but with no success.
> this is the local url used:
> SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=RIO_DE_
> JANEIRO&STYLES=&SRS=epsg:4326&BBOX=-43.7965385309,-23.
> 300&FORMAT=kml.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=
> GetMap&LAYERS=RIO_DE_JANEIRO&STYLES=&SRS=epsg:4326&BBOX=-
> for image/png works fine (tested with leaflet).
> Any tips?
> Files:
> * mapfiles:
> * https://pastebin.com/4EkahMZi
> * https://pastebin.com/DVSt4mmS
> * kml: https://pastebin.com/LYkD4ZDL
> * Result: https://user-images.githubusercontent.com/5209757/
> Thanks!
> My best regards,
> Ivan
> *_______________________________________________*
> https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20171214/4d2fa21a/attachment-0001.html>
