[mapserver-users] mapserver with kml
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Thu Dec 14 10:01:30 PST 2017
The name of the format in the GetCapabilities is
<Format>application/vnd.google-earth.kml+xml</Format>
Use that.
I have never used CRS:84 as CRS and I don't know if it really works. You can stay in WMS version 1.1.1 and SRS=EPSG:4326. Verify first with image/png that GetMap returns a map.
Read
http://www.mapserver.org/optimization/debugging.html,<http://www.mapserver.org/optimization/debugging.html> add MS_ERRORFILE and DEBUG 5 and see what you get.
-Jukka Rahkonen-
Lähettäjä: Ivan Ogasawara <ivan.ogasawara at gmail.com>
Lähetetty: 14. joulukuuta 2017 18:35
Vastaanottaja: Rahkonen Jukka (MML)
Kopio: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] mapserver with kml
Dear all, thanks :)
Carlo Ruiz,
> http://mapserver.org/input/vector/kml.html
Actually, in my case, the input should be shapefile and the outputs gtiff,png and kml.
http://mapserver.org/output/kml_output.html
Jukka Rahkonen,
> I used version 1.3.0 so that the response will open into the browser automatically.
Great! I changed to v 1.3.0 too
this is my new url request:
http://172.17.0.2/?map=/maps/dengue-Rio-de-Janeiro.map&SERVICE=WMS&VERSION=1.3.0&REQUEST=GetMap&LAYERS=RIO_DE_JANEIRO&STYLES=&CRS=CRS:84&BBOX=-43.7965385309,-23.0828926973,-43.0990394004,-22.7460202858&WIDTH=400&HEIGHT=300&FORMAT=kml
> Do you have KML in the list?
yes. Full GetCapabilities xml here: https://pastebin.com/z2myYc5m
> Did you just guess or is there somewhere wrong documentation about metadata item you have tried # "wms_format" "image/png")
I saw it at some page ... but I think I haven't seen any difference (I don't remember so well) .. so I commented this option.
> However, you must explicitly add KML into WMS outputformats in the metadata. It seems that you have played with it because you have this line commented out:
OK .. I added `wms_getmap_formatlist` parameter. I also added `wms_formatlist` to metadata layer
I also change SRS=EPSG:4326 to CRS=CRS:84
Seth,
> Ivan's problem looks to be a projection issue only.
I also added crs:84 .. but the result is the same ..
KML by specification uses only a single projection, EPSG:4326 (http://www.gdal.org/drv_kml.html)
My shapefile is defined as epsg:4326 too
The png output works fine ... maybe something in kml conversion is doing wrong ...
The log about kml request is here: https://pastebin.com/iP4h0wXx
Ivan Ogasawara
2017-12-14 10:08 GMT-04:00 Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>>:
Geoservers have KML output enabled by default so you can have a try with clients.  Test-URL
http://demo.geo-solutions.it/geoserver/wms?REQUEST=GetMap&SERVICE=WMS&VERSION=1.1.1&WIDTH=1373&HEIGHT=840&LAYERS=topp%3Astates&TRANSPARENT=TRUE&FORMAT=application/vnd.google-earth.kml+xml&BBOX=-124.731422,19.49461526802622,-66.969849,54.83308673197378&SRS=EPSG:4326&STYLES=
WMS 1.3.0 does not say anything about GetMap formats, just that they must appear in GetCapabilities, and all formats that appear in GetCapabilities must also be usable.
-Jukka Rahkonen-
Lähettäjä: Seth G [mailto:sethg at geographika.co.uk<mailto:sethg at geographika.co.uk>]
Lähetetty: 14. joulukuuta 2017 14:56
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>>; mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Interesting!
>From the WMS spec: "Graphic element formats include Scalable Vector Graphics (SVG; MIME type “image/svg+xml”) or Web Computer Graphics Metafile (WebCGM; MIME type “image/cgm;Version=4;ProfileId=WebCGM”) formats"
I wonder how many WMS clients would handle KML as a WMS. As it is XML then it would't be accessible from another domain in a web client.
Seth
web:http://geographika.co.uk
twitter: @geographika
On Thu, Dec 14, 2017, at 10:42 AM, Rahkonen Jukka (MML) wrote:
Hi Seth,
KML is considered as an image format and it should work with WMS and with mode=map http://mapserver.gis.umn.edu/fr/development/rfc/ms-rfc-58.html
It seems that KML output has not been developed much since the initial implementation.
-Jukka Rahkonen-
Lähettäjä: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Seth G
Lähetetty: 14. joulukuuta 2017 10:03
Vastaanottaja: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
Your output image looks like a projection issue. Google Maps use the espg:3857 projection, but your request is asking for SRS=epsg:4326, maybe try changing this?
Also are you trying to return KML or display an image using KML as a data source? If you are trying to return KML you'd need to use WFS rather than WMS which only returns images.
Seth
On Thu, Dec 14, 2017, at 01:33 AM, Ivan Ogasawara wrote:
Dear all,
Anyone knows some tutorial to work with mapserver (wms) and kml?
I am trying to do it .. but with no success.
this is the local url used:
http://172.17.0.2/?map=/maps/dengue-Rio-de-Janeiro.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=RIO_DE_JANEIRO&STYLES=&SRS=epsg:4326&BBOX=-43.7965385309,-23.0828926973,-43.0990394004,-22.7460202858&WIDTH=400&HEIGHT=300&FORMAT=kml.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=RIO_DE_JANEIRO&STYLES=&SRS=epsg:4326&BBOX=-43.7965385309,-23.0828926973,-43.0990394004,-22.7460202858&WIDTH=400&HEIGHT=300&FORMAT=kml
for image/png works fine (tested with leaflet).
Any tips?
Files:
* mapfiles:
  * https://pastebin.com/4EkahMZi
  * https://pastebin.com/DVSt4mmS
* kml: https://pastebin.com/LYkD4ZDL
* Result: https://user-images.githubusercontent.com/5209757/33969313-f7029096-e042-11e7-8621-e8235f0bd5ce.png
Thanks!
My best regards,
Ivan
mapserver-users mailing list
https://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20171214/0b12b4c2/attachment-0001.html>
