[mapserver-users] mapserver with kml
Ivan Ogasawara
ivan.ogasawara at gmail.com
Thu Dec 14 11:03:20 PST 2017
> The name of the format in the GetCapabilities is
> <Format>application/vnd.google-earth.kml+xml</Format>
> Use that.
yes .. this format is in my GetMap/Format
using this format name in url result this error:
msWMSLoadGetMapParams(): Image handling error. Unsupported output format
(application/vnd.google-earth.kml xml).
I think I should use the same value defined on OUTPUTFORMAT/NAME
> I have never used CRS:84 as CRS and I don't know if it
> really works. You can stay in WMS version 1.1.1 and SRS=EPSG:4326. Verify
> first with image/png that GetMap returns a map.
> I have no problem with image/png format (using 1.1.1 or 1.3.0)
> Read
> http://www.mapserver.org/optimization/debugging.html,
> <http://www.mapserver.org/optimization/debugging.html> add MS_ERRORFILE
> and DEBUG 5 and see what you get.
These parameter are already defined:
CONFIG 'ON_MISSING_DATA' 'IGNORE'
CONFIG 'PROJ_LIB' './conf/'
CONFIG "MS_ERRORFILE" "/var/log/mapserver.log"
CONFIG "CPL_DEBUG" "ON"
CONFIG "PROJ_DEBUG" "ON"
DEBUG 5
but I couldn't find any important information in the log file (
https://pastebin.com/iP4h0wXx)
this is the proj_lib/conf/ file : https://pastebin.com/AFNKC88Z
My best regards,
Ivan
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20171214/fec99b79/attachment.html>
