[mapserver-users] mapserver with kml
Ivan Ogasawara
ivan.ogasawara at gmail.com
Fri Dec 15 15:06:53 PST 2017
Dear all,
I think the problem is related to this:
https://github.com/mapserver/mapserver/issues/4938
because using this URL works fine:
http://172.17.0.2?map=/maps/dengue-Rio-de-Janeiro.map&mode=map&MAP_IMAGETYPE=KML&layers=RIO_DE_JANEIRO
I changed the image width/height ratio and works fine too!
thanks so much!
2017-12-14 18:00 GMT-04:00 Ivan Ogasawara <ivan.ogasawara at gmail.com>:
> Hi Stephen,
> 2017-12-14 15:44 GMT-04:00 Stephen Woodbridge <woodbri at swoodbridge.com>:
>> The "+" char in the URL is interpreted as a space you have to ecapce this
>> as %2B
> You're right, thanks .. but there is the same issue ...
>> But you should be able to give the OUTPUTFORMAT block an NAME "kml" and
>> give that the appropriate parameters like:
>> EXTENSION "kml"
>> MIMETYPE "application/vnd.google-earth.kml+xml"
>> and whatever other parameters are needed, then request the format "kml"
> yes .. this is the kml outputformat that I am using:
> OUTPUTFORMAT
> NAME "kml"
> DRIVER KML
> IMAGEMODE RGBA
> EXTENSION "kml"
> FORMATOPTION 'ATTACHMENT=RIO_DE_JANEIRO.kml'
> END
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20171215/56aea3fc/attachment.html>
