[mapserver-users] mapserver with kml
Ivan Ogasawara
ivan.ogasawara at gmail.com
Thu Dec 14 14:00:21 PST 2017
Hi Stephen,
2017-12-14 15:44 GMT-04:00 Stephen Woodbridge <woodbri at swoodbridge.com>:
> The "+" char in the URL is interpreted as a space you have to ecapce this
> as %2B
You're right, thanks .. but there is the same issue ...
> But you should be able to give the OUTPUTFORMAT block an NAME "kml" and
> give that the appropriate parameters like:
> EXTENSION "kml"
> MIMETYPE "application/vnd.google-earth.kml+xml"
> and whatever other parameters are needed, then request the format "kml"
yes .. this is the kml outputformat that I am using:
OUTPUTFORMAT
NAME "kml"
DRIVER KML
IMAGEMODE RGBA
EXTENSION "kml"
FORMATOPTION 'ATTACHMENT=RIO_DE_JANEIRO.kml'
END
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20171214/61231640/attachment.html>
