[mapserver-users] Σχετ: Σχετ: Σχετ: Mapfile CLASS hierarchy
Stefanos Anastasiou
emperor_stef at yahoo.gr
Mon Jan 23 10:33:05 PST 2017
Yes, that's it. Thank you very much. It's working..!!!!Although everything looks really really small on the smallest scale like 1:60.000 (which is my default scale on first load) but I guess that's how things are looking from an altitude of approximately 16 Km, right? :-) :-)
Regards,-Stefanos
Στις 7:49 μ.μ. Δευτέρα, 23 Ιανουαρίου 2017, ο/η Stephen Woodbridge <woodbri at swoodbridge.com> έγραψε:
Sorry my bad, that should be SIZEUNITS
Read the section on SIZE and WIDTH
http://mapserver.org/mapfile/style.html
It explains how SIZEUNITS is used.
On 1/23/2017 11:20 AM, Stefanos Anastasiou wrote:
> You are probably referring to the MAP level UNITS object.... Yes, I've
> already set that in meters. I've also set the
> PROJECTION
> "init:epsg=2100"
> END
> in both the MAP level and the LAYER level. My extent is in meters too,
> obtained from the ogrinfo -al -so command.
> but still..... the same effect......
> Στις 5:11 π.μ. Δευτέρα, 23 Ιανουαρίου 2017, ο/η Stephen Woodbridge
> On 1/22/2017 6:33 PM, Stefanos Anastasiou wrote:
>> Thank you for the replies.
>> This means that regardless of the layer's CLASS hierachy, the
>> attributes will be rendered according to the sorting rule, which is
>> predefined in your data. If the data are not sorted in advance, the
>> rendering will never be right. Correct?
>> If this is the case, then +1 for the sortshp. It worked out well in my
>> mapfile and roads are rendered properly.
>> However it appears that in PostGIS data, the sorting happens in the
>> DATA section of the mapfile, and the data need not be pre-sorted. It
>> works this way here, at least with the following rule:
>> DATA 'geom from (SELECT * FROM roads ORDER BY category
>> desc) AS foo using unique id using srid=2100'
>> On the other hand, I didn't quite catch the z-index part in Simon's
>> tutorial. I don't have have z values...
> Yes this all correct.
>> I'm also curious for one more thing. As more as I zoom in on my map,
>> the roads are getting smaller instead of getting bigger. Imagine a
>> highway looking pretty wide and as you zoom in the width is reducing.
>> I've only set color and width in STYLE object of my mapfile. Am I
>> missing any configuration ?
> By default units are in pixels, so a road 12 pixels width is 12 pixels
> wide regardless of zoom level. Set UNITS meter and now you road width
> will be in ground units and get width on the map as you zoom in. Youcan
> also use MINSIZE and MAXSIZE to limit the width of the roads to some
> number of pixels.
> -Steve
>> This blog entry from Simon Mercier describes how this works.
>> http://www.mapgears.com/en/blog/archive/2013-03-05-roads_network_mapping
>> Lars S.
>> -----Originalmeddelande-----
>>> Från: "Stephen Woodbridge" <woodbri at swoodbridge.com
> <mailto:woodbri at swoodbridge.com>
>> <mailto:woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>>>
>>> Till: mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> <mailto:mapserver-users at lists.osgeo.org>>
>>> Datum: 2017-01-22 05:35
>>> Ämne: Re: [mapserver-users] Mapfile CLASS hierarchy
>>> Oh, and I forgot to mention that if you want objects rendered in a
>>> particular order, then your should sort the data in the sources in that
>>> order. You can do this with order by clause on SQL based data sources
>>> and using shpsort for shapefiles, ogr2ogr and also sort data.
>>> On 1/21/2017 10:03 PM, Stephen Woodbridge wrote:
>>> > Within a layer objects are always drawn in the order they are delivered
>>> > from the datasource. Think of the CLASSes are an IF-ELSEIF-BLOCK, when
>>> > an object is presented each CLASS is tested and the first one the
>>> > accepts the object renders it.
>>> > I often up a default class at then end that has no expression ans
> render
>>> > it in red just so I can see if I missed any cases, but remove it when
>>> > I'm done developing the mapfile.
>>> > -Steve W
>>> > On 1/21/2017 8:48 PM, Stefanos Anastasiou wrote:
>>> >> Hi list,
>>> >> according to the documentation, the first layer in the mapfile is
>>> >> drawn first, and the second is drawn on top of that and so on... I was
>>> >> wondering if the same principle applies to the CLASS object as
>> well. For
>>> >> example: I have a "Roads" layer stored in PostGIS with a "Category"
>>> >> column representing the different types of roads. So a category 3 is
>>> >> very small roads, category 2 is city roads, 1 is major roads and 0 is
>>> >> highways and on the same layers I create four CLASS objects with
>>> >> different styles for each Road category. But regardless the order
>> of the
>>> >> classes (either I draw the small roads first or the highways) the same
>>> >> effect insists: the small roads are drawn over the highways. So
> what
>>> >> is the solution here? Create different layers of the same dataset
>>> >> representing the various values of the "Category" column ??
>>> >> Regards,
>>> >> -Stefanos
>>> >> _______________________________________________
>>> >> mapserver-users mailing list
>>> >> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>>> > This email has been checked for viruses by Avast antivirus software.
>>> > https://www.avast.com/antivirus
>> Στις 12:25 μ.μ. Κυριακή, 22 Ιανουαρίου 2017, ο/η
>> "lars.schylberg at blixtmail.se <mailto:lars.schylberg at blixtmail.se>"
> <lars.schylberg at blixtmail.se <mailto:lars.schylberg at blixtmail.se>> έγραψε:
>> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170123/6f87c10b/attachment-0001.html>
