[mapserver-users] Σχετ: Σχετ: Σχετ: Mapfile CLASS hierarchy
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Jan 23 11:39:03 PST 2017
On 1/23/2017 1:33 PM, Stefanos Anastasiou wrote:
> Yes, that's it. Thank you very much. It's working..!!!!
> Although everything looks really really small on the smallest scale like
> 1:60.000 (which is my default scale on first load) but I guess that's
> how things are looking from an altitude of approximately 16 Km, right?
Yes, but you can override this by setting MINSIZE <pixels>, so if you
set MINSIZE 1 then the line will never go under 1 pixel in width.
Likewise setting MAXSIZE limits the width to that number of pixels when
zooming in.
> Regards,
> -Stefanos
> Στις 7:49 μ.μ. Δευτέρα, 23 Ιανουαρίου 2017, ο/η Stephen Woodbridge
> <woodbri at swoodbridge.com> έγραψε:
> Sorry my bad, that should be SIZEUNITS
> Read the section on SIZE and WIDTH
> http://mapserver.org/mapfile/style.html
> It explains how SIZEUNITS is used.
> On 1/23/2017 11:20 AM, Stefanos Anastasiou wrote:
>> You are probably referring to the MAP level UNITS object.... Yes, I've
>> already set that in meters. I've also set the
>> PROJECTION
>> "init:epsg=2100"
>> END
>> in both the MAP level and the LAYER level. My extent is in meters too,
>> obtained from the ogrinfo -al -so command.
>> but still..... the same effect......
>> Στις 5:11 π.μ. Δευτέρα, 23 Ιανουαρίου 2017, ο/η Stephen Woodbridge
>> <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> έγραψε:
>> On 1/22/2017 6:33 PM, Stefanos Anastasiou wrote:
>>> Thank you for the replies.
>>> This means that regardless of the layer's CLASS hierachy, the
>>> attributes will be rendered according to the sorting rule, which is
>>> predefined in your data. If the data are not sorted in advance, the
>>> rendering will never be right. Correct?
>>> If this is the case, then +1 for the sortshp. It worked out well in my
>>> mapfile and roads are rendered properly.
>>> However it appears that in PostGIS data, the sorting happens in the
>>> DATA section of the mapfile, and the data need not be pre-sorted. It
>>> works this way here, at least with the following rule:
>>> DATA 'geom from (SELECT * FROM roads ORDER BY category
>>> desc) AS foo using unique id using srid=2100'
>>> On the other hand, I didn't quite catch the z-index part in Simon's
>>> tutorial. I don't have have z values...
>> Yes this all correct.
>>> I'm also curious for one more thing. As more as I zoom in on my map,
>>> the roads are getting smaller instead of getting bigger. Imagine a
>>> highway looking pretty wide and as you zoom in the width is reducing.
>>> I've only set color and width in STYLE object of my mapfile. Am I
>>> missing any configuration ?
>> By default units are in pixels, so a road 12 pixels width is 12 pixels
>> wide regardless of zoom level. Set UNITS meter and now you road width
>> will be in ground units and get width on the map as you zoom in. Youcan
>> also use MINSIZE and MAXSIZE to limit the width of the roads to some
>> number of pixels.
>> -Steve
>>> This blog entry from Simon Mercier describes how this works.
>>> http://www.mapgears.com/en/blog/archive/2013-03-05-roads_network_mapping
>>> Lars S.
>>> -----Originalmeddelande-----
>>>> Från: "Stephen Woodbridge" <woodbri at swoodbridge.com
>> <mailto:woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>>
> <mailto:woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>>>>
>>>> Till: mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> <mailto:mapserver-users at lists.osgeo.org>>
> <mailto:mapserver-users at lists.osgeo.org>>>
>>>> Datum: 2017-01-22 05:35
>>>> Ämne: Re: [mapserver-users] Mapfile CLASS hierarchy
>>>> Oh, and I forgot to mention that if you want objects rendered in a
>>>> particular order, then your should sort the data in the sources in that
>>>> order. You can do this with order by clause on SQL based data sources
>>>> and using shpsort for shapefiles, ogr2ogr and also sort data.
>>>> On 1/21/2017 10:03 PM, Stephen Woodbridge wrote:
>>>> > Within a layer objects are always drawn in the order they are
> delivered
>>>> > from the datasource. Think of the CLASSes are an IF-ELSEIF-BLOCK, when
>>>> > an object is presented each CLASS is tested and the first one the
>>>> > accepts the object renders it.
>>>> > I often up a default class at then end that has no expression ans
>> render
>>>> > it in red just so I can see if I missed any cases, but remove it when
>>>> > I'm done developing the mapfile.
>>>> > -Steve W
>>>> > On 1/21/2017 8:48 PM, Stefanos Anastasiou wrote:
>>>> >> Hi list,
>>>> >> according to the documentation, the first layer in the mapfile is
>>>> >> drawn first, and the second is drawn on top of that and so on...
> I was
>>>> >> wondering if the same principle applies to the CLASS object as
>>> well. For
>>>> >> example: I have a "Roads" layer stored in PostGIS with a "Category"
>>>> >> column representing the different types of roads. So a category 3 is
>>>> >> very small roads, category 2 is city roads, 1 is major roads and 0 is
>>>> >> highways and on the same layers I create four CLASS objects with
>>>> >> different styles for each Road category. But regardless the order
>>> of the
>>>> >> classes (either I draw the small roads first or the highways) the
> same
>>>> >> effect insists: the small roads are drawn over the highways. So
>> what
>>>> >> is the solution here? Create different layers of the same dataset
>>>> >> representing the various values of the "Category" column ??
>>>> >> Regards,
>>>> >> -Stefanos
>>>> >> _______________________________________________
>>>> >> mapserver-users mailing list
>>>> >> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>>>> > This email has been checked for viruses by Avast antivirus software.
>>>> > https://www.avast.com/antivirus
>>>> mapserver-users at lists.osgeo.org <mailto:mapserver-users at lists.osgeo.org>
>>> Στις 12:25 μ.μ. Κυριακή, 22 Ιανουαρίου 2017, ο/η
>>> "lars.schylberg at blixtmail.se <mailto:lars.schylberg at blixtmail.se>
> <mailto:lars.schylberg at blixtmail.se <mailto:lars.schylberg at blixtmail.se>>"
>> <lars.schylberg at blixtmail.se <mailto:lars.schylberg at blixtmail.se>
> <mailto:lars.schylberg at blixtmail.se>>> έγραψε:
