[mapserver-users] how remove the geometry from wfs response
Passmore, James H.
jpass at bgs.ac.uk
Fri Jun 16 02:20:31 PDT 2017
The purpose of a WFS is to return features, which are spatial objects plus properties. If I understand it you want to return just the properties? If so what you are getting are not features, and therefore a WFS is not an appropriate mechanism for you to get the data you want.
IMHO MapServer shouldn't allow this through the WFS interface (and neither should any other WFS software).
James
Date: Thu, 15 Jun 2017 20:22:04 +0200
I need to force the remove from the wfs response of the geometry . I need to avoid that the users could take the geometry and allow only the alphanumeric attributes.
Is this allowed from mapserver ?
Many thx,
Andrea
This message (and any attachments) is for the recipient only. NERC is subject to the Freedom of Information Act 2000 and the contents of this email and any reply you make may be disclosed by NERC unless it is exempt from release under the Act. Any material supplied to NERC may be stored in an electronic records management system.
