[mapserver-users] how remove the geometry from wfs response
Jörg Thomsen (WhereGroup)
joerg.thomsen at wheregroup.com
Fri Jun 16 02:38:41 PDT 2017
Hi Andrea,
Am 16.06.2017 um 10:44 schrieb Andrea Peri:
> Hi Jorg,
> I know the spec allow to reduce the attribute returned.
> The WFS spec give the parameter "propertyname" is possible to give a
> list of attribute returned.
> If in the propertyname is not list the "geometry" field it is not returned.
> So the wfs can have a response without the geometry as allowed from
> the wfs spec.
> Also I know the mapserver allow to set and exclude some attribute to
> avoid sensible information from the response using the
> parameter "gml_exclude_items" and "ows_exclude_items".
> Unfortunatelly the two parameter seem ignore the geometry field as field name.
you are right, but this concerns the request, not the service.
You are talking about attributes. The gemometry is not an attribute, but
the feature itself and a WebFeatureService which does not provide the
feautures/geometries wouldn't be a FeatureService.
Perhaps there is anybody else, who can explain it better ....
Jörg
> A.
> 2017-06-16 8:56 GMT+02:00 Jörg Thomsen (WhereGroup)
> <joerg.thomsen at wheregroup.com>:
>> Hello Andrea,
>> Am 15.06.2017 um 20:22 schrieb Andrea Peri:
>>> Hi,
>>> I need to force the remove from the wfs response of the geometry . I
>>> need to avoid that the users could take the geometry and allow only the
>>> alphanumeric attributes.
>>> Is this allowed from mapserver ?
>> This is not the purpose of a WFS. A WFS-Client would expect a gemoemtry
>> und couldn't handle the answer.
>> You may use WMS-GetFeatureInfo with GML-Output.
>> Regards, Jörg
>>> Many thx,
>>> Andrea
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Viele Grüße,
>> Jörg Thomsen
>> AGIT 2017
>> 5.-7. Juli 2017 in Salzburg
>> Besuchen Sie uns an Stand Nr. 31
>> www.agit.at
>> Jörg Thomsen
>> WhereGroup GmbH & Co. KG
>> Gillweg 3
>> 14193 Berlin
>> Germany
>> Fon: +49 (0)30 / 5130 278 74
>> Fax: +49 (0)30 / 89 09 53 21
>> www.wheregroup.com
>> Amtsgericht Bonn, HRA 6788
>> Komplementärin:
>> WhereGroup Verwaltungs GmbH
>> vertreten durch:
>> Olaf Knopp, Peter Stamm
>> Folgen Sie der WhereGroup auf twitter: http://twitter.com/WhereGroup_com
Viele Grüße,
Jörg Thomsen
AGIT 2017
www.agit.at
Jörg Thomsen
Gillweg 3
14193 Berlin
Germany
www.wheregroup.com
Komplementärin:
vertreten durch:
