[mapserver-users] how remove the geometry from wfs response
Lime, Steve D (MNIT)
steve.lime at state.mn.us
Fri Jun 16 07:51:35 PDT 2017
This behavior is documented http://mapserver.org/ogc/wfs_server.html and http://mapserver.org/output/ogr_output.html. The latter seems to contradict the documentation on the former that states that OGR output doesn't honor that metadata setting.
Steve
From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Even Rouault
Sent: Friday, June 16, 2017 5:26 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] how remove the geometry from wfs response
On jeudi 15 juin 2017 20:22:04 CEST Andrea Peri wrote:
> Hi,
> I need to force the remove from the wfs response of the geometry . I need
> to avoid that the users could take the geometry and allow only the
> alphanumeric attributes.
> Is this allowed from mapserver ?
Andrea,
Digging into the code, I found that setting in the LAYER.METADATA
"gml_geometries" "none"
will do the job.
This trick is used internally in particular to implement GetPropertyValue. But digging into history, I actually see it was done on purpose for GetFeature as well per
https://github.com/mapserver/mapserver/issues/1718
It is just that the documentation for it in is missing in
http://mapserver.org/ogc/wfs_server.html . Doesn't seem to be tested in the regression suite as far as I can see, so lucky it still works.
Note: this trick will only work for MapServer integrated GML output. OGR outputformat doesn't honour this setting.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170616/a7881c34/attachment.html>
