[mapserver-users] how remove the geometry from wfs response
Even Rouault even.rouault at spatialys.com
Fri Jun 16 08:03:50 PDT 2017
On vendredi 16 juin 2017 14:51:35 CEST Lime, Steve D (MNIT) wrote:
> This behavior is documented http://mapserver.org/ogc/wfs_server.html and
> http://mapserver.org/output/ogr_output.html. The latter seems to contradict
> the documentation on the former that states that OGR output doesn't honor
> that metadata setting.
Steve,
Are you pointing to
*ows/wfs_geomtype*
(Optional, metadata shared with OGR output[1]). Set the geometry type of OGR layers
created from this MapServer LAYER. One of “Point”, “LineString”, “Polygon”, “MultiPoint”,
“MultiLineString”, “MultiPolygon”, “GeometryCollection”, “Geometry”, or “None”
I don't see any contradiction between the 2 pages, so not sure you are pointing to this.
What I pointed to was "gml_geometries" "none"
Actually when looking in the code, my feeling is that "ows_geomtype" "None" works
mostly for OGR output. "ows_geomtype" is only taken into account by GML output to
determine if the geometry is 2.5D or not. What a mess !
> Steve
> From: mapserver-users [mailto:mapserver-users-bounces at lists.osgeo.org] On
> Behalf Of Even Rouault Sent: Friday, June 16, 2017 5:26 AM
> To: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] how remove the geometry from wfs response
> On jeudi 15 juin 2017 20:22:04 CEST Andrea Peri wrote:
> > Hi,
> > I need to force the remove from the wfs response of the geometry . I need
> > to avoid that the users could take the geometry and allow only the
> > alphanumeric attributes.
> > Is this allowed from mapserver ?
> Andrea,
> Digging into the code, I found that setting in the LAYER.METADATA
> will do the job.
> This trick is used internally in particular to implement GetPropertyValue.
> But digging into history, I actually see it was done on purpose for
> GetFeature as well per
> https://github.com/mapserver/mapserver/issues/1718
> It is just that the documentation for it in is missing in
> http://mapserver.org/ogc/wfs_server.html . Doesn't seem to be tested in the
> regression suite as far as I can see, so lucky it still works.
> Note: this trick will only work for MapServer integrated GML output. OGR
> outputformat doesn't honour this setting.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
[1] http://mapserver.org/output/ogr_output.html#ogr-output
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170616/cd2711ef/attachment-0001.html>
