[mapserver-users] how remove the geometry from wfs response
Andrea Peri aperi2007 at gmail.com
Fri Jun 16 16:30:19 PDT 2017
Hi Even,
It work !
Now is possible for us to exclude the geometry from the response.
Really thx,
Andrea.
2017-06-16 12:25 GMT+02:00 Even Rouault <even.rouault at spatialys.com>:
> On jeudi 15 juin 2017 20:22:04 CEST Andrea Peri wrote:
>> Hi,
>> I need to force the remove from the wfs response of the geometry . I need
>> to avoid that the users could take the geometry and allow only the
>> alphanumeric attributes.
>> Is this allowed from mapserver ?
> Andrea,
> Digging into the code, I found that setting in the LAYER.METADATA
> "gml_geometries" "none"
> will do the job.
> This trick is used internally in particular to implement GetPropertyValue.
> But digging into history, I actually see it was done on purpose for
> GetFeature as well per
> https://github.com/mapserver/mapserver/issues/1718
> It is just that the documentation for it in is missing in
> http://mapserver.org/ogc/wfs_server.html . Doesn't seem to be tested in the
> regression suite as far as I can see, so lucky it still works.
> Note: this trick will only work for MapServer integrated GML output. OGR
> outputformat doesn't honour this setting.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Andrea Peri
qwerty àèìòù
