[mapserver-users] wms projection wrong
Rahkonen Jukka (MML)
jukka.rahkonen at maanmittauslaitos.fi
Wed Mar 8 03:16:47 PST 2017
I do not see any screenshot in your message. This mailing list has rather strict limits for the size of the message so perhaps it has been dropped. It might be better to put your image into some image service and add a link to the mail.
You must also add more information. Write at least LAYER definitions and tell how did you test the layer and how do you know that the OSM layer is right.
-Jukka Rahkonen-
Dear all,
I installed mapserver7.0.4 on ubuntu 16.04 for a test.
I used ppa to install php_mapscript module.
Everything seems to be working, however I got an issue
on the map. As you can see on the screenshot attached
the 2 layers boundaries mismatch.
The base map is from OSM is in EPSG:4326 (WMS layer),
european countries is a shp file in the same epsg.
I guess is something related to the WMS layer projection, doesn't it?
This is very strange,
it didn't happen in mapserver 6.4.1 in ubuntu 14.04.
Of course I'm testing the same mapfile.
Any hints on that?
Eugenio
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20170308/dfc35a99/attachment.html>
